주요 콘텐츠로 건너뛰기
How do I replace the wheels on my Tobago trolley?
필요한 것
  1. How do I replace the wheels on my Tobago trolley?, Wheels: 1 단계, 이미지 1/3 How do I replace the wheels on my Tobago trolley?, Wheels: 1 단계, 이미지 2/3 How do I replace the wheels on my Tobago trolley?, Wheels: 1 단계, 이미지 3/3
    • Open the trolley and unzip the lining.
  2. How do I replace the wheels on my Tobago trolley?: 2 단계, 이미지 1/2 How do I replace the wheels on my Tobago trolley?: 2 단계, 이미지 2/2
    • Unscrew the 4 marked screws with a Phillips screwdriver.
    • When attaching the new wheels, take care not to over tighten the screws.
    • Use the flat-blade screwdriver to remove the 2 washers.
    • Removing the wheelhouse from the trolley.
    • Pinch off the two remaining rivets with the tongs.
  3. How do I replace the wheels on my Tobago trolley?: 6 단계, 이미지 1/3 How do I replace the wheels on my Tobago trolley?: 6 단계, 이미지 2/3 How do I replace the wheels on my Tobago trolley?: 6 단계, 이미지 3/3
    • Remove the other 2 rivets on the outside of the trolley using the flat-blade screwdriver. Then remove the wheelhouse from the trolley.
    • When attaching the new wheelhouse, take care not to over tighten the screws.
결론
Follow the instructions in reverse order to finish the repair.
VAUDE Reparaturteam
회원 가입일: 02/22/16
6,255 평판
안내서 32개 작성하였습니다
Vaudesport Vaudesport 회원
Community
3 회원들
안내서 96개 작성하였습니다
댓글 3개
Dear Vaude, I have a Module 60 where the airline has managed to snap of a wheel recently. I am in contact with the UK supplier of Vaude parts, but is the repair similar to above and therefore I need to order the right hand side plastic/wheel? Thank you for any help.
JANE D - 답글
Dear Jane, yes, you can use this repair guide also for your Module Trolley. You will get a set of wheels, you so can change both if you want.
VAUDE Reparaturteam -
Dear Vaude
I have a trolley Samoa, and it seems I can't get replacements like for the Tobago. Any idea how I could find wheels to replace the broken ones?
Rollo Launche - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 17
30일 전: 78
전체 시간: 4,695
