소개
As a rule of thumb, you should wash your sleeping bag after sleeping in it about 20 times. We recommend to use Nikwax Down Wash Direct for washing. While cleaning it also reconditions the water-repellency and revitalizes the isolating characteristics of the down fill. Read on to find out the best steps to wash a down sleeping bag.
필요한 것
Read the information on the care label (sewn into the footsack). In our example, down cleaner from Nikwax is recommended as well as a waterproofing spray. You’ll find the wash and care symbols on the back side of the care label.
Set the washing machine to 30 °C with a gentle cycle and put the correct amount of cleaner into the dispenser.
Set the dryer to a low temperature (30 °C). Put two or three tennis balls into the dryer along with the bag to restore the loft to the down. Dry it well and then leave the bag open for a day at a well ventilated and dry place. Shake out the bag occasionally to distribute the down.
If the outside of the sleeping bag needs to be re-waterproofed, you should choose a spray-on waterproofing. This way you can ensure that you only waterproof the outside while leaving the inside untreated so that it can absorb moisture and direct it outward.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
