주요 콘텐츠로 건너뛰기
How stuff works
    • If you want to get up to speed quickly or revise the basics, this 50 minute tutorial based on a Restart training session is just the thing!
  1. How stuff works, Electrical Theory 101: 2 단계, 이미지 1/1
    • If your volts, amps and ohms are a bit rusty (or even non-existent) then we have a simple introduction that anyone should be able to follow.
    • Start off with Volts, Amps, Watts and Ohms - what every Restarter should know.
    • So what's all this AC and DC nonsense all about, and why should I care?
  2. How stuff works, Electronic Components: 3 단계, 이미지 1/1
  3. How stuff works, Batteries - power to you!: 4 단계, 이미지 1/1
    • Batteries come in all shapes and sizes, and different types, some rechargeable and some throw-away. Here's pretty much all you need to know.
  4. How stuff works, Build on all you've learned: 5 단계, 이미지 1/1
    • Finally for this section of the wiki we cover:
    • Electric motors - different types and how they work.
    • Power supplies - they quite often fail, and to fix them you need to understand how they work.
    • How Radios Work. They contain a mass of components but if you at least understand roughly how they work you'll stand a much better chance of fixing them.
결론
Now, you're an expert!
다른 7명이 해당 안내서를 완성하였습니다.
Philip Le Riche
회원 가입일: 02/18/14
30,089 평판
안내서 47개 작성하였습니다
Restart Project Restart Project 회원
Community
19 회원들
안내서 511개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 39
전체 시간: 1,827
