주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How stuff works
    • If you want to get up to speed quickly or revise the basics, this 50 minute tutorial based on a Restart training session is just the thing!
    댓글 쓰기
  1. How stuff works, Electrical Theory 101: 2 단계, 이미지 1개 중 1개
    • If your volts, amps and ohms are a bit rusty (or even non-existent) then we have a simple introduction that anyone should be able to follow.
    • Start off with Volts, Amps, Watts and Ohms - what every Restarter should know.
    • So what's all this AC and DC nonsense all about, and why should I care?
    댓글 쓰기
  2. How stuff works, Electronic Components: 3 단계, 이미지 1개 중 1개
    댓글 쓰기
  3. How stuff works, Batteries - power to you!: 4 단계, 이미지 1개 중 1개
    • Batteries come in all shapes and sizes, and different types, some rechargeable and some throw-away. Here's pretty much all you need to know.
    댓글 쓰기
  4. How stuff works, Build on all you've learned: 5 단계, 이미지 1개 중 1개
    • Finally for this section of the wiki we cover:
    • Electric motors - different types and how they work.
    • Power supplies - they quite often fail, and to fix them you need to understand how they work.
    • How Radios Work. They contain a mass of components but if you at least understand roughly how they work you'll stand a much better chance of fixing them.
    댓글 쓰기
결론
Now, you're an expert!
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Philip Le Riche
회원 가입일: 02/18/14
32,381 평판
안내서 48개를 작성함
Restart Project Restart Project 회원
Local Repair Groups
29 회원들
안내서 408개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 55
전체 시간: 2,567
