주요 콘텐츠로 건너뛰기
Safely remove PC case stickers
필요한 것
  1. Safely remove PC case stickers, Remove the battery (Laptops only): 1 단계, 이미지 1/2 Safely remove PC case stickers, Remove the battery (Laptops only): 1 단계, 이미지 2/2
    • The procedure to remove the battery is specific to every laptop.
    • Before removing the stickers, remove the battery.
  2. Safely remove PC case stickers, Warm up the adhesive: 2 단계, 이미지 1/3 Safely remove PC case stickers, Warm up the adhesive: 2 단계, 이미지 2/3 Safely remove PC case stickers, Warm up the adhesive: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    iFixit Opening Picks (Set of 6)
    구매
    • 30-60 seconds of heat is sufficient.
    • If the sticker is thin, a guitar pick may help.
    • After removing the battery, warm up the palmrest with a hairdryer until it is warm to the touch.
    • Peel the stickers off.
  3. Safely remove PC case stickers, Clean the remaining glue: 3 단계, 이미지 1/3 Safely remove PC case stickers, Clean the remaining glue: 3 단계, 이미지 2/3 Safely remove PC case stickers, Clean the remaining glue: 3 단계, 이미지 3/3
    • While denatured alchol works, it may "strip" some rubber coatings and paint! Use good judgement!
    • After the sticker(s) have been removed, clean the residual glue with a small amount of gentle solvent.
    • Clean the solvent after a few seconds.
결승점
다른 6명이 해당 안내서를 완성하였습니다.
Nick
회원 가입일: 11/10/09
88,851 평판
안내서 49개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,528개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 46
30일 전: 137
전체 시간: 15,703
