주요 콘텐츠로 건너뛰기
How to Fix A Loose Bicycle Chain
필요한 것
  1. How to  Fix A Loose Bicycle Chain, How to  Fix A Loose Bicycle Chain: 1 단계, 이미지 2개 중 1개 How to  Fix A Loose Bicycle Chain, How to  Fix A Loose Bicycle Chain: 1 단계, 이미지 2개 중 2개
    • Determine if your chain is loose. As shown in the pictures, the bike chain is hanging low; this is an excellent indication that your bike chain is loose.
    • Your bike might have oil all over its chain and gear, so it's best to wear gloves.
  2. How to  Fix A Loose Bicycle Chain: 2 단계, 이미지 1개 중 1개
    • Use a bike stand or wall to help keep your bike from falling.
  3. How to  Fix A Loose Bicycle Chain: 3 단계, 이미지 2개 중 1개 How to  Fix A Loose Bicycle Chain: 3 단계, 이미지 2개 중 2개
    • Loosen both nuts on either side of the rear wheel using a socket wrench, rotating the wrench from left to right.
    • Be sure to not fully unscrew the nut or else the rear wheel will no longer be connected to the bike and you will have to spend time reassembling it.
  4. How to  Fix A Loose Bicycle Chain: 4 단계, 이미지 2개 중 1개 How to  Fix A Loose Bicycle Chain: 4 단계, 이미지 2개 중 2개
    • Hold the end of the bike wheel with one hand and the bike's frame with your other hand.
    • Pull the wheel back from the frame.
    • Hold the wheel in place while proceeding to the next step.
    • While holding the wheel back, your chain should stop hanging.
  5. How to  Fix A Loose Bicycle Chain: 5 단계, 이미지 2개 중 1개 How to  Fix A Loose Bicycle Chain: 5 단계, 이미지 2개 중 2개
    • Tighten both of the loose nuts using a socket wrench, rotating the wrench from right to left, while still holding the wheel back.
  6. How to  Fix A Loose Bicycle Chain: 6 단계, 이미지 2개 중 1개 How to  Fix A Loose Bicycle Chain: 6 단계, 이미지 2개 중 2개
    • Check if your chain is still loose. As shown in the pictures, your chain should have more tension making it straight rather than hanging.
    • Do not place your fingers too close to the bike gear. It may accidentally spin depending on how your bike works and trap your fingers.
결론
After reading this guide you will never have trouble with a loose chain again.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Carlos Ortiz
회원 가입일: 01/30/22
253 평판
안내서 1개를 작성함
CSU Los Angeles, Team 4-17, Briggs Spring 2022 CSU Los Angeles, Team 4-17, Briggs Spring 2022 회원
CSULA-BRIGGS-S22S4G17
1 회원
안내서 3개를 작성함
1가이드 댓글
The steps to tight the loosen chain are good. I will try it for my cycle. https://www.youtube.com/watch?v=JMdihKgC... speed internal gear bicycle). This video reflect your steps in a good manner
Kulasekara Pandian - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 45
지난 30일: 290
전체 시간: 28,969
