주요 콘텐츠로 건너뛰기
How to Access the Internal Components of an HP 15-R011DX
필요한 것
  1. How to Access the Internal Components of an HP 15-R011DX, Battery: 1 단계, 이미지 1/2 How to Access the Internal Components of an HP 15-R011DX, Battery: 1 단계, 이미지 2/2
    • Slide the lock mechanism on the left side of the laptop to the right.
  2. How to Access the Internal Components of an HP 15-R011DX: 2 단계, 이미지 1/1
    • While holding the right slide mechanism, remove the battery from the laptop.
    • The battery is not pictured here because it is missing from this particular device.
  3. How to Access the Internal Components of an HP 15-R011DX, How to Access the Internal Components of an HP 15-R011DX: 3 단계, 이미지 1/2 How to Access the Internal Components of an HP 15-R011DX, How to Access the Internal Components of an HP 15-R011DX: 3 단계, 이미지 2/2
    • Flip the laptop over to reveal screw locations.
    • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
  4. How to Access the Internal Components of an HP 15-R011DX: 4 단계, 이미지 1/2 How to Access the Internal Components of an HP 15-R011DX: 4 단계, 이미지 2/2
    • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
  5. How to Access the Internal Components of an HP 15-R011DX: 5 단계, 이미지 1/2 How to Access the Internal Components of an HP 15-R011DX: 5 단계, 이미지 2/2
    • Remove the DVD drive from the laptop.
    • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
  6. How to Access the Internal Components of an HP 15-R011DX: 6 단계, 이미지 1/3 How to Access the Internal Components of an HP 15-R011DX: 6 단계, 이미지 2/3 How to Access the Internal Components of an HP 15-R011DX: 6 단계, 이미지 3/3
    • Flip the laptop and open.
    • Detach the keyboard by prying it free from the laptop using a spudger.
    • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
    • Disconnect the keyboard ribbon cable.
  7. How to Access the Internal Components of an HP 15-R011DX: 7 단계, 이미지 1/2 How to Access the Internal Components of an HP 15-R011DX: 7 단계, 이미지 2/2
    • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
    • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
    • Pry open the plastic casing using a spudger.
    • If struggling to remove the plastic case, check that all screws have been removed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ethan Guillotte
회원 가입일: 03/20/19
517 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S2-G4, Bailey Spring 2019 UMass Dartmouth, Team S2-G4, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S2G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 540
