주요 콘텐츠로 건너뛰기
How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban
필요한 것
  1. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban, How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 1 단계, 이미지 1/1
    • Locate the wiring harness bundle, which exits the firewall underneath the brake booster.
  2. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 2 단계, 이미지 1/1
    • Identify the auxiliary wire, which is folded and taped to either the wiring harness or the fire wall.
  3. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 3 단계, 이미지 1/1
    • Use a knife to cut the tape away from the wire and unravel it.
  4. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 4 단계, 이미지 1/1
    • Run the wire against the battery box.
  5. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 5 단계, 이미지 1/3 How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 5 단계, 이미지 2/3 How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 5 단계, 이미지 3/3
    • Place the ring terminal (washer end) of the wire on the right post located at the front of the battery.
    • Place the 10 mm washer on the post.
    • Tighten the washer using a 10 mm wrench, crescent wrench, or pliers.
    • Post size and location may vary slightly in different models. The washer will fit snuggly around the correct post.
    Y'all may want to say that it takes a m6 bolt to lock it down.
    Grayson Judd - 답글
    What is the left post for? It is constant hot as well, at least on my truck. Can’t seem to find anything showing which fuse feeds it.
    Robert Abraham - 답글
  6. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 6 단계, 이미지 1/1
    • After hooking up the wire, check to make sure the 40 amp fuse is installed for the auxiliary pin.
    • If the fuse is not installed, there will be an empty space. This fuse can be purchased at any automotive shop.
    It’s not a break booster, it is a brake booster. If you are going to be an author, you should know the meaning of the words you use.
    Albert - 답글
    I’m sure it was a simple mistake. There’s no need to talk so tough cyber warrior.
    nshourds -
    THANK YOU! I scratched my head for a week trying to get this auxiliary working….after I found your information on this sight. it took less than 5 minutes to hook it up (would’ve only took 2 minutes, but I had to go back and clean the wire terminal end…then it worked!)…..and another sight on the internet wanted me to pay them 5 bucks for this same information! So, again, thank you very much!!!
    darrelwt - 답글
    What is the purpose of the other terminal, next to aux power connector?
    Rhohon - 답글
    Stud 1 and stud 2 are for. Trailer brakes 30A fuse, stud 2 12v Aux power 40A fuse. At least for my GM vehicle. 2009 Escalade. My model had both fuses in place but the studs not hooked up. Your model may have a fuse, no fuse, or even a dummy fuse like a dust cover in place. Also for this model all trailer lights are isolated and have their own fused.
    Trailer left running 15A
    Trailer left brake turn 15A
    Trailer right running 15A
    Trailer right brake turn 15A
    Reverse lights 10A
    Trailer brakes Stud 1 30A
    12V Trailer Aux Stud 2 40A
    Thomas Madison -
결승점
다른 13명이 해당 안내서를 완성하였습니다.
Lauryn Johnson
회원 가입일: 01/19/16
454 평판
안내서 1개 작성함
Oakland University, Team 6-14, Walwema Winter 2016 Oakland University, Team 6-14, Walwema Winter 2016 회원
OAK-WALWEMA-W16S6G14
1 회원
안내서 1개 작성하였습니다
댓글 6개
This sends constant power to the trailer. What if I wanted to make that power switched by the ignition so when the key is off I can be confident that the trailer won't kill my truck battery? I know I can just unplug the trailer harness or pull this fuse to stop it, but That might be easy to forget to do.
Eric Wonderlich Jr. - 답글
Eric, did you ever get an answer to your inquiry about killing the power to the trailer when the key is in the off position?
Bobby Burke -
Albert - 답글
Never fails some troll somewhere..
Garry Foster -
“Words have meaning” geez Cyber Warrior. Tough talk from a distance. ?
nshourds -
What thread pitch of nut is it for the terminal stud.
Kenny Man - 답글
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 54
30일 전: 198
전체 시간: 33,615
