주요 콘텐츠로 건너뛰기
How to Add New Holes to Birkenstock Sandal Straps
필요한 것
  1. How to Add New Holes to Birkenstock Sandal Straps, How to Add New Holes to Birkenstock Sandal Straps: 1 단계, 이미지 2개 중 1개 How to Add New Holes to Birkenstock Sandal Straps, How to Add New Holes to Birkenstock Sandal Straps: 1 단계, 이미지 2개 중 2개
    • Unbuckle the straps on the sandal.
  2. How to Add New Holes to Birkenstock Sandal Straps: 2 단계, 이미지 2개 중 1개 How to Add New Holes to Birkenstock Sandal Straps: 2 단계, 이미지 2개 중 2개
    • Lay the long straps flat on the wooden block.
  3. How to Add New Holes to Birkenstock Sandal Straps: 3 단계, 이미지 1개 중 1개
    • Measure the distance between the holes on the strap.
    • This will allow the new hole to look neat and aligned with the original holes. The holes are typically about a centimeter apart.
  4. How to Add New Holes to Birkenstock Sandal Straps: 4 단계, 이미지 1개 중 1개
    • Use the measurement from Step 3 to measure the distance between an existing hole and the new hole you're adding.
    • Mark where your new hole will be on the strap with a pencil.
  5. How to Add New Holes to Birkenstock Sandal Straps: 5 단계, 이미지 2개 중 1개 How to Add New Holes to Birkenstock Sandal Straps: 5 단계, 이미지 2개 중 2개
    • Place the nail on the pencil mark on the strap, and hammer it through so the nail goes completely through the strap and into the wood under the strap.
    • Hammer the nail straight down in order to avoid damage to the leather or suede strap.
  6. How to Add New Holes to Birkenstock Sandal Straps: 6 단계, 이미지 1개 중 1개
    • Buckle the straps and make sure the pin on the buckle is able to go through the new hole.
    • If the pin is unable to go through the hole, put the nail back through the hole with your hand. Wiggle it around in the hole in order to expand the hole slightly. Do this until the pin is able to go through the hole.
결승점
작성자
2다른 기여자 명과 함께
Nafkot Kidane
회원 가입일: 09/28/21
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 54
지난 30일: 263
전체 시간: 32,507
