주요 콘텐츠로 건너뛰기
How to Add a Hole in a Leather Belt
필요한 것
  1. How to Add a Hole in a Leather Belt, How to Add a Hole in a Leather Belt: 1 단계, 이미지 1개 중 1개
    • Make sure the leather belt is clean by wiping it down with water and drying it before working on it beforehand to get rid of any excess dirt or grime.
  2. How to Add a Hole in a Leather Belt: 2 단계, 이미지 1개 중 1개
    • Find a flat and durable surface to work on, preferably a wooden work table. If that’s not available, then use a good sized wooden block to work on.
  3. How to Add a Hole in a Leather Belt: 3 단계, 이미지 1개 중 1개
    • Using a measuring tape, measure the distance between each of the existing holes to figure out the distance to place your new hole.
  4. How to Add a Hole in a Leather Belt: 4 단계, 이미지 1개 중 1개
    • Mark where you want the hole with either a pen or indent using the pin punch. Mark as many as you see fit before continuing onto the next step.
  5. How to Add a Hole in a Leather Belt: 5 단계, 이미지 1개 중 1개
    • Align the pin punch where you marked the hole.
    • Make sure to tighten the grip on the pin before hammering onto the marked area. Continue this for all the other hole marks.
  6. How to Add a Hole in a Leather Belt: 6 단계, 이미지 1개 중 1개
    • Push the pin all the way through the hole to make sure the hole is fully formed.
  7. How to Add a Hole in a Leather Belt: 7 단계, 이미지 1개 중 1개
    • Clean off any stray leather bits left from the hole placement using a razor blade.
결론
Once you complete all your steps, make sure to congratulate yourself on your new belt! Now you can hold up anything you need without any issues.
작성자
1다른 기여자 명과 함께
Feliza Castillo
회원 가입일: 05/24/23
195 평판
안내서 1개를 작성함
York University, Team A-2, Allen Summer 2023 York University, Team A-2, Allen Summer 2023 회원
YORK-ALLEN-SU23SAG2
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 38
전체 시간: 735
