주요 콘텐츠로 건너뛰기
How to Adjust Black and Decker TR1278B Browning Dial
필요한 것
  1. How to Adjust Black and Decker TR1278B Browning Dial, Top Cover: 1 단계, 이미지 1/1
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. How to Adjust Black and Decker TR1278B Browning Dial: 2 단계, 이미지 1/1
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. How to Adjust Black and Decker TR1278B Browning Dial: 3 단계, 이미지 1/1
    • Detach the bottom from the front cover using the plastic opening tool.
  4. How to Adjust Black and Decker TR1278B Browning Dial: 4 단계, 이미지 1/1
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. How to Adjust Black and Decker TR1278B Browning Dial: 5 단계, 이미지 1/1
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
  6. How to Adjust Black and Decker TR1278B Browning Dial, How to Adjust Black and Decker TR1278B Browning Dial: 6 단계, 이미지 1/2 How to Adjust Black and Decker TR1278B Browning Dial, How to Adjust Black and Decker TR1278B Browning Dial: 6 단계, 이미지 2/2
    • Remove the front cover.
  7. How to Adjust Black and Decker TR1278B Browning Dial: 7 단계, 이미지 1/2 How to Adjust Black and Decker TR1278B Browning Dial: 7 단계, 이미지 2/2
    • Unscrew the circuit behind the browning dial on the front cover.
    • Do not lose the washers on the screws.
  8. How to Adjust Black and Decker TR1278B Browning Dial: 8 단계, 이미지 1/1
    • Remove the circuit.
    • The dial and buttons on the front cover will be loose.
  9. How to Adjust Black and Decker TR1278B Browning Dial: 9 단계, 이미지 1/1
    • Turn the knob on the circuit board left or right to adjust the browning dial.
결론
Dominic Gamonez
회원 가입일: 02/15/17
233 평판
안내서 2개 작성하였습니다
USF Tampa, Team 8-1, Eyestone Spring 2017 USF Tampa, Team 8-1, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S8G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 687
