주요 콘텐츠로 건너뛰기
How to Adjust Cantilever Bicycle Brakes
필요한 것
  1. How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: 1 단계, 이미지 1/3 How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: 1 단계, 이미지 2/3 How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: 1 단계, 이미지 3/3
    • Lift bicycle onto the rear wheel by holding the handlebars.
    • Roll the rear wheel forward while placing the handlebars on the ground so that the bike rests upside down.
  2. How to Adjust Cantilever Bicycle Brakes: 2 단계, 이미지 1/2 How to Adjust Cantilever Bicycle Brakes: 2 단계, 이미지 2/2
    • Identify the brake that is rubbing against the bike rim by spinning each wheel while listening for contact.
    • Identify which brake pad is making contact (left or right).
  3. How to Adjust Cantilever Bicycle Brakes: 3 단계, 이미지 1/3 How to Adjust Cantilever Bicycle Brakes: 3 단계, 이미지 2/3 How to Adjust Cantilever Bicycle Brakes: 3 단계, 이미지 3/3
    • Loosen the 6mm hex screw that is holding the noisy brake to the frame.
    • Make sure not to remove the bolt completely.
  4. How to Adjust Cantilever Bicycle Brakes: 4 단계, 이미지 1/1
    • Shift the brake so that the pad no longer makes contact with the rim.
  5. How to Adjust Cantilever Bicycle Brakes: 5 단계, 이미지 1/2 How to Adjust Cantilever Bicycle Brakes: 5 단계, 이미지 2/2
    • Rotate the bicycle tire to ensure the brake is no longer rubbing against the rim.
    • Keep your fingers free of the spokes while the wheel is spinning!
  6. How to Adjust Cantilever Bicycle Brakes: 6 단계, 이미지 1/2 How to Adjust Cantilever Bicycle Brakes: 6 단계, 이미지 2/2
    • Hold the brake in the new position where it no longer rubs.
    • Use the 6 mm hex key to tighten the brake bolt back on.
  7. How to Adjust Cantilever Bicycle Brakes: 7 단계, 이미지 1/2 How to Adjust Cantilever Bicycle Brakes: 7 단계, 이미지 2/2
    • Rotate the wheel again to ensure the brake did not change positions while you were tightening it.
  8. How to Adjust Cantilever Bicycle Brakes: 8 단계, 이미지 1/1
    • Flip the bike back onto its wheels.
결론
Go ride your bike!
다른 한 분이 해당 안내서를 완성하였습니다.
Devaughantee
회원 가입일: 09/30/20
194 평판
안내서 1개 작성함
York University, Team S4-G21, Woodhouse Fall 2020 York University, Team S4-G21, Woodhouse Fall 2020 회원
YORK-WOODHOUSE-F20S4G21
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 38
전체 시간: 758
