주요 콘텐츠로 건너뛰기
How to Adjust Cantilever Bicycle Brakes
필요한 것
  1. How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: 1 단계, 이미지 3개 중 1개 How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: 1 단계, 이미지 3개 중 2개 How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: 1 단계, 이미지 3개 중 3개
    • Lift bicycle onto the rear wheel by holding the handlebars.
    • Roll the rear wheel forward while placing the handlebars on the ground so that the bike rests upside down.
  2. How to Adjust Cantilever Bicycle Brakes: 2 단계, 이미지 2개 중 1개 How to Adjust Cantilever Bicycle Brakes: 2 단계, 이미지 2개 중 2개
    • Identify the brake that is rubbing against the bike rim by spinning each wheel while listening for contact.
    • Identify which brake pad is making contact (left or right).
  3. How to Adjust Cantilever Bicycle Brakes: 3 단계, 이미지 3개 중 1개 How to Adjust Cantilever Bicycle Brakes: 3 단계, 이미지 3개 중 2개 How to Adjust Cantilever Bicycle Brakes: 3 단계, 이미지 3개 중 3개
    • Loosen the 6mm hex screw that is holding the noisy brake to the frame.
    • Make sure not to remove the bolt completely.
  4. How to Adjust Cantilever Bicycle Brakes: 4 단계, 이미지 1개 중 1개
    • Shift the brake so that the pad no longer makes contact with the rim.
  5. How to Adjust Cantilever Bicycle Brakes: 5 단계, 이미지 2개 중 1개 How to Adjust Cantilever Bicycle Brakes: 5 단계, 이미지 2개 중 2개
    • Rotate the bicycle tire to ensure the brake is no longer rubbing against the rim.
    • Keep your fingers free of the spokes while the wheel is spinning!
  6. How to Adjust Cantilever Bicycle Brakes: 6 단계, 이미지 2개 중 1개 How to Adjust Cantilever Bicycle Brakes: 6 단계, 이미지 2개 중 2개
    • Hold the brake in the new position where it no longer rubs.
    • Use the 6 mm hex key to tighten the brake bolt back on.
  7. How to Adjust Cantilever Bicycle Brakes: 7 단계, 이미지 2개 중 1개 How to Adjust Cantilever Bicycle Brakes: 7 단계, 이미지 2개 중 2개
    • Rotate the wheel again to ensure the brake did not change positions while you were tightening it.
  8. How to Adjust Cantilever Bicycle Brakes: 8 단계, 이미지 1개 중 1개
    • Flip the bike back onto its wheels.
결론
Go ride your bike!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Devaughantee
회원 가입일: 09/30/20
194 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 1,152
