주요 콘텐츠로 건너뛰기
How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes
필요한 것
  1. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes, How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 1 단계, 이미지 1개 중 1개
    • You will see a cable attached to an Allen bolt.
  2. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 2 단계, 이미지 1개 중 1개
    • Loosen up the bolt with the help of Hex key set.
  3. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 3 단계, 이미지 2개 중 1개 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 3 단계, 이미지 2개 중 2개
    • Now, pull the cable as much as you can.
  4. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 4 단계, 이미지 1개 중 1개
    • Tighten up the bolt while you keep pulling the cable.
  5. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 5 단계, 이미지 2개 중 1개 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 5 단계, 이미지 2개 중 2개
    • To center the caliper for a smooth breaking experience, loosen up the two bolts of the brake situated at top and at bottom.
  6. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 6 단계, 이미지 1개 중 1개
    • Now, put the brake on.
  7. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 7 단계, 이미지 3개 중 1개 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 7 단계, 이미지 3개 중 2개 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 7 단계, 이미지 3개 중 3개
    • While putting the brake on, tighten up both the bolts.
    • You are finished adjusting the brakes!
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Md Abdullah
회원 가입일: 07/03/21
201 평판
안내서 1개를 작성함
댓글 2개
Dude, the cable is attached incorrectly. The cable routes up and over the little arm.
Grandy - 답글
I need a replacement t25 bolt and square ribbed nut that is shown in step 4. Any help would be stellar.
gr8fuljqr - 답글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 39
지난 30일: 95
전체 시간: 5,598
