주요 콘텐츠로 건너뛰기
How to Adjust a Garden Fountain Hose
필요한 것
  1. How to Adjust a Garden Fountain Hose, How to Adjust a Garden Fountain Hose: 1 단계, 이미지 1/3 How to Adjust a Garden Fountain Hose, How to Adjust a Garden Fountain Hose: 1 단계, 이미지 2/3 How to Adjust a Garden Fountain Hose, How to Adjust a Garden Fountain Hose: 1 단계, 이미지 3/3
    • Turn off and unplug the fountain.
    • Remove the water from the fountain using a cup.
    • Empty the water into a bucket and place the bucket off to the side and out of the way.
  2. How to Adjust a Garden Fountain Hose: 2 단계, 이미지 1/3 How to Adjust a Garden Fountain Hose: 2 단계, 이미지 2/3 How to Adjust a Garden Fountain Hose: 2 단계, 이미지 3/3
    • Remove the screws along the edge of the platform on the bottom half of the fountain using a Phillips screwdriver.
    • Lift the upper half of the fountain upward while holding onto the water pump.
  3. How to Adjust a Garden Fountain Hose: 3 단계, 이미지 1/3 How to Adjust a Garden Fountain Hose: 3 단계, 이미지 2/3 How to Adjust a Garden Fountain Hose: 3 단계, 이미지 3/3
    • Lay the upper half of the fountain on a flat surface such as a table.
    • Remove the hose from the water pump.
    • Cut the hose an inch and a half shorter from the original length using a pair of scissors.
  4. How to Adjust a Garden Fountain Hose: 4 단계, 이미지 1/3 How to Adjust a Garden Fountain Hose: 4 단계, 이미지 2/3 How to Adjust a Garden Fountain Hose: 4 단계, 이미지 3/3
    • Remove the screws at the bottom of the platform using a Phillips head screwdriver.
    • Remove the platform from the bottom of the upper half of the fountain and place the platform on the side.
  5. How to Adjust a Garden Fountain Hose: 5 단계, 이미지 1/3 How to Adjust a Garden Fountain Hose: 5 단계, 이미지 2/3 How to Adjust a Garden Fountain Hose: 5 단계, 이미지 3/3
    • Loosen the clamp using a flathead screwdriver.
    • Slide the clamp onto the hose until the clamp is at the end of the hose against the surface of the bottom of the fountain.
    • Tighten the clamp using a flathead screwdriver.
  6. How to Adjust a Garden Fountain Hose: 6 단계, 이미지 1/3 How to Adjust a Garden Fountain Hose: 6 단계, 이미지 2/3 How to Adjust a Garden Fountain Hose: 6 단계, 이미지 3/3
    • Place the platform on the bottom of the fountain.
    • Place the platform so that the holes where the screws enter are aligned.
    • Place the screws into the holes and screw them into place using a Phillips head screwdriver.
    • Attach the hose to the water pump.
  7. How to Adjust a Garden Fountain Hose: 7 단계, 이미지 1/3 How to Adjust a Garden Fountain Hose: 7 단계, 이미지 2/3 How to Adjust a Garden Fountain Hose: 7 단계, 이미지 3/3
    • Place the upper half of the fountain onto the bottom half.
    • Align the holes where the screws enter.
    • Refill the fountain with water, plug it in, and turn it on.
결승점
Vivian Rivera
회원 가입일: 10/25/23
145 평판
안내서 1개 작성함
CSU Los Angeles, Team 4-19, Kershman Fall 2023 CSU Los Angeles, Team 4-19, Kershman Fall 2023 회원
CSULA-KERSHMAN-F23S4G19
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 24
전체 시간: 59
