주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Adjust a Piano Key Slip
필요한 것
  1. How to Adjust a Piano Key Slip, How to Adjust a Piano Key Slip: 1 단계, 이미지 3개 중 1개 How to Adjust a Piano Key Slip, How to Adjust a Piano Key Slip: 1 단계, 이미지 3개 중 2개 How to Adjust a Piano Key Slip, How to Adjust a Piano Key Slip: 1 단계, 이미지 3개 중 3개
    • Locate the keys that hold your key slip to the piano.
    • They are typically underneath the piano keyboard and there will be between two and four screws.
    • Check to see what kind of screw it is. In the case of this piano, it is a flathead screw; however there could be a variety of screws.
  2. How to Adjust a Piano Key Slip: 2 단계, 이미지 3개 중 1개 How to Adjust a Piano Key Slip: 2 단계, 이미지 3개 중 2개 How to Adjust a Piano Key Slip: 2 단계, 이미지 3개 중 3개
    • Remove all the screws from the piano and set them aside.
  3. How to Adjust a Piano Key Slip: 3 단계, 이미지 2개 중 1개 How to Adjust a Piano Key Slip: 3 단계, 이미지 2개 중 2개
    • Gently remove your key slip using your hands.
    • The key slip is the piece of wood that sits in front of the keys.
  4. How to Adjust a Piano Key Slip: 4 단계, 이미지 3개 중 1개 How to Adjust a Piano Key Slip: 4 단계, 이미지 3개 중 2개 How to Adjust a Piano Key Slip: 4 단계, 이미지 3개 중 3개
    • Check for debris under the keys.
    • You can vacuum out dust or remove pieces of paper and other objects that have fallen behind the key slip or through the keys.
  5. How to Adjust a Piano Key Slip: 5 단계, 이미지 3개 중 1개 How to Adjust a Piano Key Slip: 5 단계, 이미지 3개 중 2개 How to Adjust a Piano Key Slip: 5 단계, 이미지 3개 중 3개
    • Replace your key slip, ensuring that it sits evenly between the two ends of the piano.
  6. How to Adjust a Piano Key Slip: 6 단계, 이미지 3개 중 1개 How to Adjust a Piano Key Slip: 6 단계, 이미지 3개 중 2개 How to Adjust a Piano Key Slip: 6 단계, 이미지 3개 중 3개
    • Re-screw the key slip onto the piano.
    • Don't tighten the screws all the way down at first. Screw each one in a little bit to make it doesn't become uneven.
    • Go back and tighten the screws to your desired tightness.
    • Check the keys to make sure that the they are no longer sticking, and that the key slip is not too tight.
  7. How to Adjust a Piano Key Slip: 7 단계, 이미지 3개 중 1개 How to Adjust a Piano Key Slip: 7 단계, 이미지 3개 중 2개 How to Adjust a Piano Key Slip: 7 단계, 이미지 3개 중 3개
    • Check each key to make sure they are no longer sticking.
    • If you were successful, no keys will stick and your key slip will be properly placed!
결론
Congratulations! Your keys are no longer sticky and if your key slip slips out of place again you now know how to fix it!
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Chloe Nielsen
회원 가입일: 11/17/21
184 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 85
전체 시간: 2,455
