주요 콘텐츠로 건너뛰기
How to Adjust a Violin Bow
  1. How to Adjust a Violin Bow, How to Adjust a Violin Bow: 1 단계, 이미지 2개 중 1개 How to Adjust a Violin Bow, How to Adjust a Violin Bow: 1 단계, 이미지 2개 중 2개
    • Identify the adjusting screw at the butt end of the bow.
  2. How to Adjust a Violin Bow: 2 단계, 이미지 1개 중 1개
    • Carefully unscrew the adjusting screw .
  3. How to Adjust a Violin Bow: 3 단계, 이미지 1개 중 1개
    • Once you fully unscrew the adjusting screw, carefully remove both the frog and the adjusting screw from the bow.
  4. How to Adjust a Violin Bow: 4 단계, 이미지 1개 중 1개
    • While not allowing the hair to become tangled, insert a small part of the adjusting screw so that only a small portion of the tip is seen. You do not need to screw the adjusting screw into the eyelet.
  5. How to Adjust a Violin Bow: 5 단계, 이미지 2개 중 1개 How to Adjust a Violin Bow: 5 단계, 이미지 2개 중 2개
    • Carefully move the adjusting screw to tighten the eyehole, moving in a clockwise direction. To loosen, move the eyehole in a counter-clockwise direction.
    • Do not screw more than 180 degrees during adjustment to ensure you do not damage the bow.
  6. How to Adjust a Violin Bow: 6 단계, 이미지 1개 중 1개
    • Once you have either tightened or loosened the eyehole by 180 degrees, remove the adjusting screw from the eyehole.
    • Once you have finished, make sure the hairs are not tangled and have not become damaged during the adjusting process.
결론
작성자
2다른 기여자 명과 함께
Julia Kellum
회원 가입일: 01/28/20
142 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 1,131
