주요 콘텐츠로 건너뛰기
How to Adjust the Truss Rod on an Acoustic Guitar
필요한 것
  1. How to Adjust the Truss Rod on an Acoustic Guitar, How to Adjust the Truss Rod on an Acoustic Guitar: 1 단계, 이미지 3개 중 1개 How to Adjust the Truss Rod on an Acoustic Guitar, How to Adjust the Truss Rod on an Acoustic Guitar: 1 단계, 이미지 3개 중 2개 How to Adjust the Truss Rod on an Acoustic Guitar, How to Adjust the Truss Rod on an Acoustic Guitar: 1 단계, 이미지 3개 중 3개
    • Unwind and remove the strings
    • Turn the tuning pegs to release tension in the strings, and then pull the strings away, detaching them from the headstock
  2. How to Adjust the Truss Rod on an Acoustic Guitar: 2 단계, 이미지 3개 중 1개 How to Adjust the Truss Rod on an Acoustic Guitar: 2 단계, 이미지 3개 중 2개 How to Adjust the Truss Rod on an Acoustic Guitar: 2 단계, 이미지 3개 중 3개
    • Remove the truss rod cover with the necessary tool (depending on your guitar).
    • A Phillips 0 screwdriver is used here to unscrew the 2 x 1/4" Small Phillips guitar screws from the truss rod cover.
    • There are three screws holding the truss rod cover in place.
  3. How to Adjust the Truss Rod on an Acoustic Guitar: 3 단계, 이미지 2개 중 1개 How to Adjust the Truss Rod on an Acoustic Guitar: 3 단계, 이미지 2개 중 2개
    • Use the Allen Wrench to adjust the truss rod according to the warp of the neck.
    • For a forward or “U-shaped” bow, turn the truss rod counterclockwise. For a backward bow adjustment, adjust the truss rod clockwise.
    • A “U-shaped” bow is too tight; it has extra space toward the center of the neck, and bows outward and toward the strings. A backward bow is too loose; it arches inward and away from the strings.
  4. How to Adjust the Truss Rod on an Acoustic Guitar: 4 단계, 이미지 3개 중 1개 How to Adjust the Truss Rod on an Acoustic Guitar: 4 단계, 이미지 3개 중 2개 How to Adjust the Truss Rod on an Acoustic Guitar: 4 단계, 이미지 3개 중 3개
    • Re-string the guitar by reattatching them to the headstock.
    • Turn the tuning pegs to bring the strings back to tension.
    • At the same time, adjust the bridge evenly with the neck ( if it is not already glued into the saddle) by moving it with your hand.
  5. How to Adjust the Truss Rod on an Acoustic Guitar: 5 단계, 이미지 1개 중 1개
    • Using your eyes or a metal ruler, check the distance from the strings to the frets on the neck.
    • You can use a metal ruler to measure out approximately 2.5 mm for an acoustic guitar, depending on your preference.
  6. How to Adjust the Truss Rod on an Acoustic Guitar: 6 단계, 이미지 1개 중 1개
    • Using the Allen Wrench, make any final adjustments to the truss while the strings are at tension.
    • You may use a tuner to help adjust the strings to the desired tension
  7. How to Adjust the Truss Rod on an Acoustic Guitar: 7 단계, 이미지 2개 중 1개 How to Adjust the Truss Rod on an Acoustic Guitar: 7 단계, 이미지 2개 중 2개
    • Replace the truss rod cover.
    • Re-tune the guitar.
결론
Reattach the truss rod cover to the headstock of your guitar using the 2 x 1/4 “ Phillips screws and Phillips 0 screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Taryn Wilson
회원 가입일: 10/07/19
172 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 17
전체 시간: 2,374
