주요 콘텐츠로 건너뛰기
How to Alter a Large Dress to Fit
필요한 것
  1. How to Alter a Large Dress to Fit, How to Alter a Large Dress to Fit: 1 단계, 이미지 1개 중 1개
    • Put on your dress.
    • Pinching the waistline, grab your ruler and measure from your hip.
    • This number will tell you how much you need to take in to make your dress fit.
  2. How to Alter a Large Dress to Fit: 2 단계, 이미지 1개 중 1개
    • Turn your dress inside out and lay it on a smooth surface.
    • Using your measurements from Step 1, measure out evenly from the seam line how much you need to take in on each side.
    • As you measure how much you take in, use the clothespins as a marker.
  3. How to Alter a Large Dress to Fit: 4 단계, 이미지 1개 중 1개
    • Carefully put on your dress to make sure that it fits you in the right way.
    • Now that your dress fits how you would like, carefully take it off and lay it back on a flat surface.
    • Using chalk or a pen, make a line that connects all the pins.
    • This line will be a guide for when you use the sewing machine.
  4. How to Alter a Large Dress to Fit: 6 단계, 이미지 1개 중 1개
    • Thread your sewing machine.
    • If you need help on how to thread the sewing machine, here is a guide on how to.
    • Carefully push your dress through and begin sewing your new seam.
  5. How to Alter a Large Dress to Fit: 7 단계, 이미지 1개 중 1개
    • When you're done sewing your dress, flip it so that it is right side out and put it on.
    • If there is any excess fabric, you can cut it away, leaving 1/4 of an inch of the leftover fabric by the seam.
결론
This is an easy and low budget way to fix a dress that is too large. Check the tag on the dress to see how you should care for it after. It is best recommended that you let your dress air dry.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Viviane Dobis
회원 가입일: 10/21/20
145 평판
안내서 1개를 작성함
Texas Tech, Team S14-G7, Cowan Fall 2020 Texas Tech, Team S14-G7, Cowan Fall 2020 회원
TTU-COWAN-F20S14G7
2 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 21
전체 시간: 1,488
