주요 콘텐츠로 건너뛰기
How to Alter the Waist of Jeans
필요한 것
  1. How to Alter the Waist of Jeans, How to Alter the Waist of Jeans: 1 단계, 이미지 1개 중 1개
    • Put on the jeans and pinch the extra fabric at the centre back of the waistband.
  2. How to Alter the Waist of Jeans: 2 단계, 이미지 1개 중 1개
    • Mark both sides of the pinched fabric with chalk on the outside of the jeans.
    • You may do this step while wearing the jeans.
  3. How to Alter the Waist of Jeans: 3 단계, 이미지 3개 중 1개 How to Alter the Waist of Jeans: 3 단계, 이미지 3개 중 2개 How to Alter the Waist of Jeans: 3 단계, 이미지 3개 중 3개
    • Draw a diagonal line from each marked spot to the centre back seam.
  4. How to Alter the Waist of Jeans: 4 단계, 이미지 2개 중 1개 How to Alter the Waist of Jeans: 4 단계, 이미지 2개 중 2개
    • Pass the thread through the loop on the needle threader.
    • Pull the needle threader out of the eye of the needle and create a knot at the end.
    • Use a double thread or a thick thread for durability.
    • For more information on using a needle threader, use the How to Use a Needle Threader Guide.
  5. How to Alter the Waist of Jeans: 5 단계, 이미지 2개 중 1개 How to Alter the Waist of Jeans: 5 단계, 이미지 2개 중 2개
    • Begin sewing from the inside out, starting beside the belt loop.
    • Bring the needle across the marked spot and sew it inside out.
  6. How to Alter the Waist of Jeans: 6 단계, 이미지 2개 중 1개 How to Alter the Waist of Jeans: 6 단계, 이미지 2개 중 2개
    • Move the needle horizontally, then insert and thread it through the fabric a short distance below the starting point.
    • Repeat this process until the thread reaches the centre back seam.
  7. How to Alter the Waist of Jeans: 7 단계, 이미지 3개 중 1개 How to Alter the Waist of Jeans: 7 단계, 이미지 3개 중 2개 How to Alter the Waist of Jeans: 7 단계, 이미지 3개 중 3개
    • Pull the thread to conceal the stitches.
  8. How to Alter the Waist of Jeans: 8 단계, 이미지 2개 중 1개 How to Alter the Waist of Jeans: 8 단계, 이미지 2개 중 2개
    • Bring the thread back to the inside of the jeans, tie a knot, and cut the excess thread.
  9. How to Alter the Waist of Jeans: 9 단계, 이미지 1개 중 1개
    • Repeat steps 4-8 on the other side.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Zoe Kim
회원 가입일: 09/19/23
215 평판
안내서 1개를 작성함
York University, Team B-30, Woodhouse Fall 2023 York University, Team B-30, Woodhouse Fall 2023 회원
YORK-WOODHOUSE-F23SBG30
1 회원
안내서 5개를 작성함
1가이드 댓글
Thank you very much for your help. You showed me a new way to tighten the waist on jeans
Monika Skubij (Mon) - 답글
댓글 쓰기
조회 통계:
지난 24시간: 19
지난 7일: 119
지난 30일: 557
전체 시간: 5,503
