주요 콘텐츠로 건너뛰기
How to Apple Wireless Keyboard Reset
동영상 개요
  1. How to Apple Wireless Keyboard Reset, Switch off the Apple Wireless Keyboard: 1 단계, 이미지 3개 중 1개 How to Apple Wireless Keyboard Reset, Switch off the Apple Wireless Keyboard: 1 단계, 이미지 3개 중 2개 How to Apple Wireless Keyboard Reset, Switch off the Apple Wireless Keyboard: 1 단계, 이미지 3개 중 3개
    • Switch off the keyboard by holding down the power button for at least 3 seconds
    • Open "System Preferences...", "Bluetooth".
  2. How to Apple Wireless Keyboard Reset: 2 단계, 이미지 3개 중 1개 How to Apple Wireless Keyboard Reset: 2 단계, 이미지 3개 중 2개 How to Apple Wireless Keyboard Reset: 2 단계, 이미지 3개 중 3개
    • Remove Your Apple Wireless Keyboard
  3. How to Apple Wireless Keyboard Reset: 3 단계, 이미지 2개 중 1개 How to Apple Wireless Keyboard Reset: 3 단계, 이미지 2개 중 2개
    • Follow the steps to pair Your Keyboard
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
195,943 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,452개를 작성함
5가이드 댓글
I bought a wireless keyboard at a flea market. When pairing I was able to enter all numbers, but the "Enter" key does not react. Is there some way to test the button?
Rainer Stumpf - 답글
Same for me. The problem was the enter key: there are 2 switches down the key but only the top one is pressed and this is broken. I removed the key, put a plastic spacer on the second switch and reassembled the key, all ok now.
Nemo Capitano -
Pairing my A1255 to my 2011 MacBook Pro, after many press and hold button attempts to reset, it was unsuccessful. Until I brought both the laptop and the keyboard to a insulated staircase of the building so no other Bluetooth devices are present, the two connected.
Vu Linh - 답글
ho provato a resettarla ma niente da fare funziona solo parzialmente .l’ho collegata all’iPad 11 pro e funziona perfettamente
victor
Vittorio Panebianco - 답글
Nonostante i vari tentativi di reset della tastiera Apple A1314, non si abbina al mac Pro 6,1
Vincenzo - 답글
댓글 쓰기
조회 통계:
지난 24시간: 19
지난 7일: 123
지난 30일: 593
전체 시간: 103,007
