주요 콘텐츠로 건너뛰기
How to Apply a Screen Protector for iPhone11 Pro Max
필요한 것
  1. How to Apply a Screen Protector for iPhone11 Pro Max, How to Apply a Screen Protector for iPhone11 Pro Max: 1 단계, 이미지 1/2 How to Apply a Screen Protector for iPhone11 Pro Max, How to Apply a Screen Protector for iPhone11 Pro Max: 1 단계, 이미지 2/2
    • Wipe the dust off the screen with a No. 1 alcohol cleaning wipe.
    • This will help to avoid bubbles when applying the screen protector.
  2. How to Apply a Screen Protector for iPhone11 Pro Max: 2 단계, 이미지 1/1
    • Use a dry wipe to wipe off any water stains on the screen.
  3. How to Apply a Screen Protector for iPhone11 Pro Max: 3 단계, 이미지 1/3 How to Apply a Screen Protector for iPhone11 Pro Max: 3 단계, 이미지 2/3 How to Apply a Screen Protector for iPhone11 Pro Max: 3 단계, 이미지 3/3
    • Tear off one of the dust removal tape strips.
    • Use the dust removal tape to clean off the fine dust.
  4. How to Apply a Screen Protector for iPhone11 Pro Max: 4 단계, 이미지 1/3 How to Apply a Screen Protector for iPhone11 Pro Max: 4 단계, 이미지 2/3 How to Apply a Screen Protector for iPhone11 Pro Max: 4 단계, 이미지 3/3
    • Put the auxiliary tool on your phone.
    • Push down so that the auxiliary tool is firmly attached to the phone.
    • This step is not necessary, and it doesn't matter if you don't have it. The auxiliary tool is just to assist you place the screen protector straight.
  5. How to Apply a Screen Protector for iPhone11 Pro Max: 5 단계, 이미지 1/3 How to Apply a Screen Protector for iPhone11 Pro Max: 5 단계, 이미지 2/3 How to Apply a Screen Protector for iPhone11 Pro Max: 5 단계, 이미지 3/3
    • Take out the screen protector. Tear off the release layer of the screen protector (the thinner side).
    • Aim the holes of the screen protector at the holes of the auxiliary tool and then slowly lay the screen protector onto the screen.
  6. How to Apply a Screen Protector for iPhone11 Pro Max: 6 단계, 이미지 1/3 How to Apply a Screen Protector for iPhone11 Pro Max: 6 단계, 이미지 2/3 How to Apply a Screen Protector for iPhone11 Pro Max: 6 단계, 이미지 3/3
    • Wipe the screen surface around with a dry wipe to make the screen protector fit the phone screen better and lay flat.
  7. How to Apply a Screen Protector for iPhone11 Pro Max: 7 단계, 이미지 1/3 How to Apply a Screen Protector for iPhone11 Pro Max: 7 단계, 이미지 2/3 How to Apply a Screen Protector for iPhone11 Pro Max: 7 단계, 이미지 3/3
    • Pull off the the auxiliary tool with your fingers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Qiyuan Feng
회원 가입일: 05/10/21
169 평판
안내서 1개 작성함
York University, Team S1-G6, O'Regan Summer 2021 York University, Team S1-G6, O'Regan Summer 2021 회원
YORK-O'REGAN-SU21S1G6
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 34
전체 시간: 2,047
