주요 콘텐츠로 건너뛰기
How to Bind Transmitter and Reciever
필요한 것
    • Disconnect the power cable and remove the battery
    • If using a transmitter other than the Blade MLP4DSM, add a new model to the transmitter.
    • Select the appropriate model type.
    • Center all trims on the transmitter.
    • If using the Blade MLP4DSM, press the trim buttons until you hear a long low beep (roll and pitch trim) or three short low beeps (throttle and yaw trim). This indicates that the trim is centered.
    • Turn the power off on the transmitter.
    • Make sure the throttle is in the off position.
    • If using a transmitter other than the Blade MLP4DSM, make sure that all switches are in the 0 position.
    • Reconnect the power cable to the battery.
    • Make sure not to bend the pins on the connector.
    • After 5 seconds, the status LED will turn blue and begin flashing rapidly, indicating that it has entered bind mode.
    • Put the transmitter into bind mode while powering it on.
    • If using the Blade MLP4DSM, push and hold the left stick while powering on the transmitter. Release the left stick. You will hear a beep and the power LED will blink.
    • If using a different transmitter, consult the manual on how to enter bind mode.
    • The status LED will turn solid blue when it is successfully bound to the transmitter.
    • Disconnect the battery from the power cable.
    • Power off the transmitter.
결론
You should now be ready to fly your quadcopter.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ian Glen
회원 가입일: 04/28/14
651 평판
안내서 3개를 작성함
2가이드 댓글
That worked perfectly for me! And I used the MLP6 transmitter. Thanks kid! ;)
jamiekif - 답글
The drone is bound now but I cant get it to arm. Any suggestions? Not sure how to do it on this controller. Thank you!
rob_swain - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 38
전체 시간: 5,984
