주요 콘텐츠로 건너뛰기
How to Bind a Book Spine
필요한 것
  1. How to Bind a Book Spine, How to Bind a Book Spine: 1 단계, 이미지 1/1
    • First, grab the book you would like to fix.
  2. How to Bind a Book Spine: 2 단계, 이미지 1/1
    • Then, open the book to where you have the most access to the exposed inner spine.
  3. How to Bind a Book Spine: 3 단계, 이미지 1/1
    • Shake up the glue before removing the cap.
    • Then, test glue on a piece of paper before placing it on the spine of the book. It should be about the consistency of Elmer's glue.
  4. How to Bind a Book Spine: 4 단계, 이미지 1/1
    • Place the glue along the spine opposite of the cover. Make sure you are distributing glue evenly.
    • You may also choose to use a paint brush to make sure area is completely covered with glue.
    • Glue is runny; use with caution.
  5. How to Bind a Book Spine: 5 단계, 이미지 1/1
    • After placing the glue, wrap the cover tightly around the book.
    • Firmly drag your fingers down the spine of the book to avoid any air pockets.
    • Remove any excess glue with a tissue.
    • For the demonstration we held the book as shown. You may also choose to place something on top of the book, such as a paperweight or another book, and let it sit for 30 to 40 minutes.
  6. How to Bind a Book Spine: 6 단계, 이미지 1/1
    • After the glue is dry, you should be able to lightly tug on the pages without any movement.
    • If movement occurs then allow the glue an additional 10 to 15 minutes to dry. Once dry, you've completed your book repair.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Britne Misner
회원 가입일: 09/30/16
149 평판
안내서 1개 작성함
Missouri Western, Team 1-13, Adkins Fall 2016 Missouri Western, Team 1-13, Adkins Fall 2016 회원
MWSU-ADKINS-F16S1G13
2 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 60
전체 시간: 1,289
