주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Blanket Stitch
필요한 것
  1. How to Blanket Stitch, How to Blanket Stitch: 1 단계, 이미지 2개 중 1개 How to Blanket Stitch, How to Blanket Stitch: 1 단계, 이미지 2개 중 2개
    • Pick a thread of your choice: fabric or sewing thread.
    • Cut a relatively long piece.
  2. How to Blanket Stitch: 2 단계, 이미지 3개 중 1개 How to Blanket Stitch: 2 단계, 이미지 3개 중 2개 How to Blanket Stitch: 2 단계, 이미지 3개 중 3개
    • Pull one end of thread through the eye of the needle.
    • Make the two tail ends meet.
    • Tie a knot.
  3. How to Blanket Stitch: 3 단계, 이미지 1개 중 1개
    • Lay your blanket (or piece of fabric) in front of you and pick your stitching direction.
    • We are stitching left to right!
  4. How to Blanket Stitch: 4 단계, 이미지 2개 중 1개 How to Blanket Stitch: 4 단계, 이미지 2개 중 2개
    • Measure about half an inch from the edge of your blanket and mark it.
    • Send your needle through the blanket from the back from the marked point.
    • When pushing your needle through the blanket make sure your fingers are not near the needle.
  5. How to Blanket Stitch: 5 단계, 이미지 1개 중 1개
    • Bring the thread around the fabric and push the needle through the very first stich creating a loop.
    • Do not pull the thread all the way though, as you will need the loop for the next step.
  6. How to Blanket Stitch: 6 단계, 이미지 2개 중 1개 How to Blanket Stitch: 6 단계, 이미지 2개 중 2개
    • Push the needle through the loop and pull.
  7. How to Blanket Stitch: 7 단계, 이미지 3개 중 1개 How to Blanket Stitch: 7 단계, 이미지 3개 중 2개 How to Blanket Stitch: 7 단계, 이미지 3개 중 3개
    • Move about half an inch from the first stitch.
    • Send the needle through the blanket from the back creating a loop.
  8. How to Blanket Stitch: 8 단계, 이미지 2개 중 1개 How to Blanket Stitch: 8 단계, 이미지 2개 중 2개
    • Push the needle through the loop and pull and repeat!
  9. How to Blanket Stitch: 9 단계, 이미지 2개 중 1개 How to Blanket Stitch: 9 단계, 이미지 2개 중 2개
    • Repeat the process through the edge of your blanket till you reach the end.
결론
To reverse these steps, use a pair of scissors to cut the thread.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
katya
회원 가입일: 05/10/21
286 평판
안내서 1개를 작성함
York University, Team S1-G5, O'Regan Summer 2021 York University, Team S1-G5, O'Regan Summer 2021 회원
YORK-O'REGAN-SU21S1G5
1 회원
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 26
지난 30일: 116
전체 시간: 2,665
