주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Buff an Apple Watch
필요한 것
  1. How to Buff an Apple Watch, How to Buff an Apple Watch: 1 단계, 이미지 2개 중 1개 How to Buff an Apple Watch, How to Buff an Apple Watch: 1 단계, 이미지 2개 중 2개
    • Flip the watch over so it is face down.
  2. How to Buff an Apple Watch: 2 단계, 이미지 3개 중 1개 How to Buff an Apple Watch: 2 단계, 이미지 3개 중 2개 How to Buff an Apple Watch: 2 단계, 이미지 3개 중 3개
    • Remove the straps by pressing the button adjacent to each side and sliding the band right out.
  3. How to Buff an Apple Watch: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    • Clean the watch with a microfiber cloth.
    • Make sure all smudges are removed at this point.
  4. How to Buff an Apple Watch: 4 단계, 이미지 3개 중 1개 How to Buff an Apple Watch: 4 단계, 이미지 3개 중 2개 How to Buff an Apple Watch: 4 단계, 이미지 3개 중 3개
    • Put on Gloves. Using a polishing cloth, which is already soaked with polishing cream, rub one side of the watch back and forth.
    • Repeat on each side of the watch.
    • When using the polishing cloth, do NOT go directly over the microphone or the speaker.
    • If the polishing cloth begins to turn black while you are wiping, do not be alarmed. The blackness is just layers of dirt coming off the watch.
  5. How to Buff an Apple Watch: 5 단계, 이미지 1개 중 1개
    • Grab your microfiber cloth and go over the same area that you previously wiped until the residue is gone and you have restored the side to it’s previous mirror finish.
  6. How to Buff an Apple Watch: 6 단계, 이미지 2개 중 1개 How to Buff an Apple Watch: 6 단계, 이미지 2개 중 2개
    • After the watch has been restored, slide the straps back into place (you will feel a click).
결론
Congratulations! You have finished buffing your Apple watch!
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Goose
회원 가입일: 07/31/17
170 평판
안내서 1개를 작성함
1가이드 댓글
Does this work for the gold or graphite cases as well?
David Fernandes - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 55
전체 시간: 8,975
