주요 콘텐츠로 건너뛰기
How to Calibrate the Fingerprint Sensor in your Google Pixel Phone
  1. How to Calibrate the Fingerprint Sensor in your Google Pixel Phone, Connect your phone: 1 단계, 이미지 3개 중 1개 How to Calibrate the Fingerprint Sensor in your Google Pixel Phone, Connect your phone: 1 단계, 이미지 3개 중 2개 How to Calibrate the Fingerprint Sensor in your Google Pixel Phone, Connect your phone: 1 단계, 이미지 3개 중 3개
    • Follow these instructions to enable developer options and USB debugging mode.
    • If you're using a Windows operating system, download the Google USB driver and follow these instructions to install it.
    • Navigate to this page to prepare the calibration software.
    • If your phone isn't turned off, do so now.
    • Hold down the power and volume down buttons on your phone for three seconds to enter Fastboot mode.
    • Your phone will show a red warning triangle with the caption "Fastboot mode."
    • Plug your phone into your computer.
  2. How to Calibrate the Fingerprint Sensor in your Google Pixel Phone, Perform the calibration: 2 단계, 이미지 3개 중 1개 How to Calibrate the Fingerprint Sensor in your Google Pixel Phone, Perform the calibration: 2 단계, 이미지 3개 중 2개 How to Calibrate the Fingerprint Sensor in your Google Pixel Phone, Perform the calibration: 2 단계, 이미지 3개 중 3개
    • Select the "Connect Device" button.
    • Choose your device from the pop-up menu.
    • Depending on your browser, your pop-up menu will look different.
    • If your device isn't showing up, select the "Troubleshooting tips" link near the bottom of the page to diagnose your issue.
    • Once your device connects, select the "Install software" button.
  3. How to Calibrate the Fingerprint Sensor in your Google Pixel Phone: 3 단계, 이미지 3개 중 1개 How to Calibrate the Fingerprint Sensor in your Google Pixel Phone: 3 단계, 이미지 3개 중 2개 How to Calibrate the Fingerprint Sensor in your Google Pixel Phone: 3 단계, 이미지 3개 중 3개
    • Wait for the calibration software to download and install.
    • The program will run automatically and restart your phone.
    • After you receive the "Install successful" prompt, unplug your phone and manually restart it again to complete the calibration.
    • If you don't manually restart your phone, your fingerprint sensor will not work properly.
결론
Your fingerprint sensor is calibrated and ready for use.
If the calibration fails for any reason, repeat the calibration procedure.
다른 295명이 해당 안내서를 완성하였습니다.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
213,136 평판
안내서 1,040개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,629개를 작성함
118가이드 댓글
When I try and use the calibration tool on my Pixel 6 I get an error message whilst downloading the software that says "Couldn't find the unique calibration software for this device". Any suggestions as to what is causing this?
Isheanesu Gambe - 답글
Same problem. Pixel 7 android 14 latest update
Gleb -
Same problem. Pixel 6 android 14 latest update
Pavel Dolínek -
Same problem, pixel 7 android 14 January update
Sunggat Yerzhan -
same problem. Please help
Stalyn Moreno Briones -
댓글 쓰기
조회 통계:
지난 24시간: 336
지난 7일: 2,389
지난 30일: 10,950
전체 시간: 301,384
