주요 콘텐츠로 건너뛰기
How to Change a Stretched Canvas
필요한 것
  1. How to Change a Stretched Canvas, How to Change a Stretched Canvas: 1 단계, 이미지 2개 중 1개 How to Change a Stretched Canvas, How to Change a Stretched Canvas: 1 단계, 이미지 2개 중 2개
    • Place the canvas upside down on a flat surface.
  2. How to Change a Stretched Canvas: 2 단계, 이미지 2개 중 1개 How to Change a Stretched Canvas: 2 단계, 이미지 2개 중 2개
    • Place the picker tool under the staple
    • Begin to lift the staple off of the frame by moving the picker tool down towards the table.
    • Lift the staple halfway up (Do not completely remove yet).
    • Don't place your hands directly in front of pointy end of the picker tool.
  3. How to Change a Stretched Canvas: 3 단계, 이미지 2개 중 1개 How to Change a Stretched Canvas: 3 단계, 이미지 2개 중 2개
    • Once the staple is halfway lifted, use the pliers to completely lift the staple from the frame.
    • Repeat steps 2-3 to remove the rest of staples.
  4. How to Change a Stretched Canvas: 4 단계, 이미지 1개 중 1개
    • Roll up your canvas for storage.
    • Roll the canvas with your painting on the outside to avoid cracking
  5. How to Change a Stretched Canvas: 5 단계, 이미지 3개 중 1개 How to Change a Stretched Canvas: 5 단계, 이미지 3개 중 2개 How to Change a Stretched Canvas: 5 단계, 이미지 3개 중 3개
    • Measure out the amount of canvas that is needed to cover the edges of the frame.
    • Once measured, make a small cut in the corner.
    • Use your hands to rip off the excess fabric.
  6. How to Change a Stretched Canvas: 6 단계, 이미지 2개 중 1개 How to Change a Stretched Canvas: 6 단계, 이미지 2개 중 2개
    • Fold one side of the canvas fabric over the edge of one of the long sides of the frame.
    • While holding the canvas down, use the staple gun to place one staple in the middle
  7. How to Change a Stretched Canvas: 7 단계, 이미지 3개 중 1개 How to Change a Stretched Canvas: 7 단계, 이미지 3개 중 2개 How to Change a Stretched Canvas: 7 단계, 이미지 3개 중 3개
    • Go over to the other side of the frame and use the canvas pliers to grab the canvas fabric. To tighten canvas fabric, begin by holding the pliers at a 45 degree angle then moving the pliers down towards the table.
    • Place the canvas pliers where you intend to place a staple .
    • While holding the fabric down, place a staple in the middle of that side of the frame.
    • Continue Step 7 on the two short sides of the frame.
  8. How to Change a Stretched Canvas: 8 단계, 이미지 3개 중 1개 How to Change a Stretched Canvas: 8 단계, 이미지 3개 중 2개 How to Change a Stretched Canvas: 8 단계, 이미지 3개 중 3개
    • Choose one of the long sides of the frame and begin stapling from the center to about 3 inches away from the corner using the same canvas plier technique from step 7. Then repeat on other long side.
    • Next, repeat this stapling process on the two short sides
  9. How to Change a Stretched Canvas: 9 단계, 이미지 2개 중 1개 How to Change a Stretched Canvas: 9 단계, 이미지 2개 중 2개
    • Trim the corner of the fabric to make folding easier.
    • The fabric that you cut away should be in the shape of a triangle.
    • Repeat on the other three corners.
  10. How to Change a Stretched Canvas: 10 단계, 이미지 3개 중 1개 How to Change a Stretched Canvas: 10 단계, 이미지 3개 중 2개 How to Change a Stretched Canvas: 10 단계, 이미지 3개 중 3개
    • Choose one corner of the frame and tuck excess fabric inside the fold.
    • Holding tightly onto the fabric, pull the fold up and over the the edge of the frame. Staple to secure both sides of the corner.
  11. How to Change a Stretched Canvas: 11 단계, 이미지 2개 중 1개 How to Change a Stretched Canvas: 11 단계, 이미지 2개 중 2개
    • When you are finished, stretched canvas should be tight and it should sound like a drum when you tap on it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Vanessa Munguia
회원 가입일: 02/04/19
247 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 45
전체 시간: 2,687
