주요 콘텐츠로 건너뛰기
How to Change an Indoor Doorknob Handle
필요한 것
  1. How to Change an Indoor Doorknob Handle, How to Change an Indoor Doorknob Handle: 1 단계, 이미지 1/1
    • Parts: (in order from left to right)
    • Short Screws
    • Latch mechanism with latch face
    • Long screws
    • Door knob with peg and screw holes (inside of the room)
    • Door knob with screw holes (outside of the room)
  2. How to Change an Indoor Doorknob Handle: 2 단계, 이미지 1/1
    • Face the inside of the knob, you should see two Phillips head screws on either side of the central knob.
  3. How to Change an Indoor Doorknob Handle: 3 단계, 이미지 1/1
    • Unscrew both long screws.
  4. How to Change an Indoor Doorknob Handle: 4 단계, 이미지 1/1
    • Remove the door knob on both sides of the door.
  5. How to Change an Indoor Doorknob Handle: 5 단계, 이미지 1/1
    • You will see the latch face plate (the rectangular piece of metal) where the latch of the door knob is located.
  6. How to Change an Indoor Doorknob Handle: 6 단계, 이미지 1/1
    • Unscrew the two short screws on the latch face plate.
  7. How to Change an Indoor Doorknob Handle: 7 단계, 이미지 1/1
    • Remove the latch face plate and latch mechanism.
  8. How to Change an Indoor Doorknob Handle: 8 단계, 이미지 1/1
    • Push the new latch mechanism with latch face plate into the door.
    • The slanted side of the latch mechanism will be facing the direction that the door closes.
  9. How to Change an Indoor Doorknob Handle: 9 단계, 이미지 1/1
    • Screw in both short screws of the latch face plate.
  10. How to Change an Indoor Doorknob Handle: 10 단계, 이미지 1/1
    • Insert the door knob that goes on the inside of the room, aligning the peg and screw holes with the threaded cylinders of the latch mechanism.
  11. How to Change an Indoor Doorknob Handle: 11 단계, 이미지 1/1
    • Align the door knob that goes on the outside of the room, aligning the peg and screw holes with the threaded cylinders of the latch mechanism.
  12. How to Change an Indoor Doorknob Handle: 12 단계, 이미지 1/1
    • Screw in both long screws on both sides of the door knob.
  13. How to Change an Indoor Doorknob Handle: 13 단계, 이미지 1/1
    • Turn the door knob to test your work.
결론
To put the old door knob back on or to change to a different door knob repeat steps from the beginning.
다른 6명이 해당 안내서를 완성하였습니다.
Mallory
회원 가입일: 02/19/15
220 평판
안내서 1개 작성함
CSU Stanislaus, Team 1-1, Moberly Spring 2015 CSU Stanislaus, Team 1-1, Moberly Spring 2015 회원
CSUS-MOBERLY-S15S1G1
4 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 49
전체 시간: 9,278
