주요 콘텐츠로 건너뛰기
How to Check Your iPhone's Battery Health
  1. How to Check Your iPhone's Battery Health, How to Check Your iPhone's Battery Health: 1 단계, 이미지 1개 중 1개
    • In order to proceed with this guide, your device must be running iOS 11.3 or higher.
    • Open the Settings app.
  2. How to Check Your iPhone's Battery Health: 2 단계, 이미지 1개 중 1개
    • Scroll down and select Battery.
  3. How to Check Your iPhone's Battery Health: 3 단계, 이미지 1개 중 1개
    • Select Battery Health.
  4. How to Check Your iPhone's Battery Health: 4 단계, 이미지 1개 중 1개
    • Maximum Capacity displays the total charge capacity of the battery compared to when the device was brand new.
    • Over many charge and discharge cycles, this number will gradually drop.
    • Your iPhone should continue to work fine, albeit with shortened battery life. Apple typically recommends replacing the battery once it degrades to 80% or lower.
  5. How to Check Your iPhone's Battery Health: 5 단계, 이미지 3개 중 1개 How to Check Your iPhone's Battery Health: 5 단계, 이미지 3개 중 2개 How to Check Your iPhone's Battery Health: 5 단계, 이미지 3개 중 3개
    • Peak Performance Capability tells you whether your battery can still supply sufficient power for the iPhone's most intense processing tasks. Normal peak performance is what you're aiming for.
    • If it says your iPhone has experienced an expected shutdown, that means your battery couldn't supply the needed power quickly enough, and the system shut down as a result.
    • Your iPhone will throttle its own performance—slowing itself down—in order to prevent further unexpected shutdowns. This can be disabled to manually enable peak performance.
    • Once you disable performance management, you cannot enable it again. It is automatically enabled after an unexpected shutdown.
    • Once your battery falls below a specific threshold (typically 80%), you will be notified that your battery's health is significantly degraded.
    • Follow this guide to replace your iPhone X battery, or click here for other iPhone models.
결론
That's all folks!
다른 28명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Josh M
회원 가입일: 11/24/14
913 평판
안내서 1개를 작성함
iTech West Palm Beach iTech West Palm Beach 회원
Business
5 회원들
안내서 7개를 작성함
4가이드 댓글
Battery Health no funciona con las baterías iFixit.
Cambié la batería de mi iPhone 6 por una batería iFixit y no se puede ver el porcentaje de batería máximo. Aparece “reparar“.
Con alguna aplicación de análisis de batería muestra 98%.
Jairo Ochoa - 답글
Under “Battery Health,” my iPhone SE says only “Service” and gives none of the information listed here.
Jeremy Nichols - 답글
Most likely your battery is below the recommended threshold and should be replaced.
If you replaced your battery, it may continue to say “Service”. I would recommend using a computer app like coconutBattery to check.
Josh M -
mine iphone 6 cannot watch battery health
gfght - 답글
댓글 쓰기
조회 통계:
지난 24시간: 49
지난 7일: 100
지난 30일: 236
전체 시간: 13,614
