주요 콘텐츠로 건너뛰기
How to Check a Car's Tire Pressure
필요한 것
  1. How to Check a Car's Tire Pressure, How to Check a Car's Tire Pressure: 1 단계, 이미지 1/2 How to Check a Car's Tire Pressure, How to Check a Car's Tire Pressure: 1 단계, 이미지 2/2
    • Your car's tire pressure information is likely located inside the car door frame toward the bottom.
    • You can also look up this information in your vehicle's owner's manual.
    • Do not refer to the tire pressure information printed on the tire itself! This displays the maximum tire pressure allowed, rather than the recommended amount.
  2. How to Check a Car's Tire Pressure: 2 단계, 이미지 1/3 How to Check a Car's Tire Pressure: 2 단계, 이미지 2/3 How to Check a Car's Tire Pressure: 2 단계, 이미지 3/3
    • Each tire has a valve stem located on the outer part of the wheel that sticks out.
    • Remove the cap by unscrewing it counter-clockwise and set it off to the side.
    • The cap is very small, so be sure to keep track of it!
  3. How to Check a Car's Tire Pressure: 3 단계, 이미지 1/2 How to Check a Car's Tire Pressure: 3 단계, 이미지 2/2
    • Place the stem of the tire pressure gauge onto the tire's valve stem and push on it with a decent amount of force.
    • You'll hear a brief hissing noise as the valve stem quickly opens and closes. If the noise continues, you likely aren't pressing down hard enough.
    • After a second or two, remove the tire pressure gauge. Again, you'll hear a brief hissing noise.
  4. How to Check a Car's Tire Pressure: 4 단계, 이미지 1/2 How to Check a Car's Tire Pressure: 4 단계, 이미지 2/2
    • Check the gauge to see what the tire pressure is. If it's low, add air to the tire until the gauge reads the proper tire pressure.
    • To reset the gauge to zero, press down on the gauge's bleeder valve.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Craig Lloyd
회원 가입일: 02/10/16
35,418 평판
안내서 82개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 53
전체 시간: 1,891
