주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Check a Car's Tire Pressure
필요한 것
  1. How to Check a Car's Tire Pressure, How to Check a Car's Tire Pressure: 1 단계, 이미지 2개 중 1개 How to Check a Car's Tire Pressure, How to Check a Car's Tire Pressure: 1 단계, 이미지 2개 중 2개
    • Your car's tire pressure information is likely located inside the car door frame toward the bottom.
    • You can also look up this information in your vehicle's owner's manual.
    • Do not refer to the tire pressure information printed on the tire itself! This displays the maximum tire pressure allowed, rather than the recommended amount.
    댓글 쓰기
  2. How to Check a Car's Tire Pressure: 2 단계, 이미지 3개 중 1개 How to Check a Car's Tire Pressure: 2 단계, 이미지 3개 중 2개 How to Check a Car's Tire Pressure: 2 단계, 이미지 3개 중 3개
    • Each tire has a valve stem located on the outer part of the wheel that sticks out.
    • Remove the cap by unscrewing it counter-clockwise and set it off to the side.
    • The cap is very small, so be sure to keep track of it!
    댓글 쓰기
  3. How to Check a Car's Tire Pressure: 3 단계, 이미지 2개 중 1개 How to Check a Car's Tire Pressure: 3 단계, 이미지 2개 중 2개
    • Place the stem of the tire pressure gauge onto the tire's valve stem and push on it with a decent amount of force.
    • You'll hear a brief hissing noise as the valve stem quickly opens and closes. If the noise continues, you likely aren't pressing down hard enough.
    • After a second or two, remove the tire pressure gauge. Again, you'll hear a brief hissing noise.
    댓글 쓰기
  4. How to Check a Car's Tire Pressure: 4 단계, 이미지 2개 중 1개 How to Check a Car's Tire Pressure: 4 단계, 이미지 2개 중 2개
    • Check the gauge to see what the tire pressure is. If it's low, add air to the tire until the gauge reads the proper tire pressure.
    • To reset the gauge to zero, press down on the gauge's bleeder valve.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
Craig Lloyd
회원 가입일: 02/10/16
42,921 평판
안내서 82개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 22
지난 30일: 121
전체 시간: 4,102
