주요 콘텐츠로 건너뛰기
How to Clean Calcium Deposits From a Sprinkler Head
필요한 것
  1. How to Clean Calcium Deposits From a Sprinkler Head, How to Clean Calcium Deposits From a Sprinkler Head: 1 단계, 이미지 2개 중 1개 How to Clean Calcium Deposits From a Sprinkler Head, How to Clean Calcium Deposits From a Sprinkler Head: 1 단계, 이미지 2개 중 2개
    • Place your fingers under the edges of the smaller circle, then slowly lift the head.
    • Keep a hose close by to make it easier to clean the basket.
  2. How to Clean Calcium Deposits From a Sprinkler Head: 2 단계, 이미지 2개 중 1개 How to Clean Calcium Deposits From a Sprinkler Head: 2 단계, 이미지 2개 중 2개
    • Twist the head counter clockwise to remove the sprinkler head from the neck, exposing the basket.
  3. How to Clean Calcium Deposits From a Sprinkler Head: 3 단계, 이미지 2개 중 1개 How to Clean Calcium Deposits From a Sprinkler Head: 3 단계, 이미지 2개 중 2개
    • If working with two people, use one hand to hold the base of the neck so the sprinkler doesn't fall back into the body of the sprinkler.
    • If working by yourself, slowly release the neck back down. It is still retrievable by twisting the head back on and repeating the process in step 2.
  4. How to Clean Calcium Deposits From a Sprinkler Head: 4 단계, 이미지 1개 중 1개
    • Use the hose to wash out the basket of any dirt or calcium deposits.
  5. How to Clean Calcium Deposits From a Sprinkler Head: 5 단계, 이미지 1개 중 1개
    • Reassemble the head, placing back the basket in the center of the neck and twisting the head clockwise to tighten it down.
  6. How to Clean Calcium Deposits From a Sprinkler Head: 6 단계, 이미지 1개 중 1개
    • Release the neck and the sprinkler is clean and ready for use.
결론
Once the head is reassembled the water flow should no longer be obstructed and should regain the full range of spray.
작성자
1다른 기여자 명과 함께
Max Warrick
회원 가입일: 07/03/23
133 평판
안내서 1개를 작성함
1가이드 댓글
question: What is the flathead screw in the center of the sprinkler head for?
David Franco - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 19
전체 시간: 730
