주요 콘텐츠로 건너뛰기
How to Clean Canon PIXMA MP190 Print Head Nozzle
  1. How to Clean Canon PIXMA MP190 Print Head Nozzle, Turn printer on.: 1 단계, 이미지 1개 중 1개
    • The printer needs to be on in order to change the ink cartridges.
  2. How to Clean Canon PIXMA MP190 Print Head Nozzle, Locate Ink Cartridges: 2 단계, 이미지 3개 중 1개 How to Clean Canon PIXMA MP190 Print Head Nozzle, Locate Ink Cartridges: 2 단계, 이미지 3개 중 2개 How to Clean Canon PIXMA MP190 Print Head Nozzle, Locate Ink Cartridges: 2 단계, 이미지 3개 중 3개
    • To locate the ink cartridges the paper output tray must be in the lowered position.
    • Next lift the scanning unit until the scanning support is vertical.
    • Lower the scanning unit until the scanning unit support seats in the scanning unit support slot.
  3. How to Clean Canon PIXMA MP190 Print Head Nozzle, Remove Ink Cartridge: 3 단계, 이미지 3개 중 1개 How to Clean Canon PIXMA MP190 Print Head Nozzle, Remove Ink Cartridge: 3 단계, 이미지 3개 중 2개 How to Clean Canon PIXMA MP190 Print Head Nozzle, Remove Ink Cartridge: 3 단계, 이미지 3개 중 3개
    • Allow the printer to position the ink cartridge carrier into the ink cartridge removal location.
    • Before replacing the ink cartridge ensure the correct ink cartridge is installed.
    • Push down on the front edge of the ink cartridge.
    • Observe the angle at which the ink cartridge is removed.
    • Grasp ink cartridge and pull up and out to remove.
  4. How to Clean Canon PIXMA MP190 Print Head Nozzle, Clean Ink Nozzle: 4 단계, 이미지 3개 중 1개 How to Clean Canon PIXMA MP190 Print Head Nozzle, Clean Ink Nozzle: 4 단계, 이미지 3개 중 2개 How to Clean Canon PIXMA MP190 Print Head Nozzle, Clean Ink Nozzle: 4 단계, 이미지 3개 중 3개
    • Hold the ink cartridge with the ink nozzle facing up. Using a paper towel firmly wipe the entire ink nozzle.
    • Repeat until the nozzle appears free of any ink and debris.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Garret Wescott
회원 가입일: 10/23/14
597 평판
안내서 4개를 작성함
Michigan Tech, Team 1-5, Lauer Fall 2014 Michigan Tech, Team 1-5, Lauer Fall 2014 회원
MTU-LAUER-F14S1G5
3 회원들
안내서 5개를 작성함
1가이드 댓글
is ther an easy way to gain access to the roller at the rear of the machine to clean it
hope342 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 50
전체 시간: 6,293
