주요 콘텐츠로 건너뛰기
How to Clean Dust Out of a Playstation 5 Without Opening It
필요한 것
  1. How to Clean Dust Out of a Playstation 5 Without Opening It, Remove the stand screw: 1 단계, 이미지 1개 중 1개
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. How to Clean Dust Out of a Playstation 5 Without Opening It, Remove the vertical stand: 2 단계, 이미지 2개 중 1개 How to Clean Dust Out of a Playstation 5 Without Opening It, Remove the vertical stand: 2 단계, 이미지 2개 중 2개
    • Lift straight up to remove the stand.
  3. How to Clean Dust Out of a Playstation 5 Without Opening It, Store the stand screw: 3 단계, 이미지 2개 중 1개 How to Clean Dust Out of a Playstation 5 Without Opening It, Store the stand screw: 3 단계, 이미지 2개 중 2개
    • Insert the screw into the cubby on the bottom of the stand.
  4. How to Clean Dust Out of a Playstation 5 Without Opening It, Cap the screw hole: 4 단계, 이미지 3개 중 1개 How to Clean Dust Out of a Playstation 5 Without Opening It, Cap the screw hole: 4 단계, 이미지 3개 중 2개 How to Clean Dust Out of a Playstation 5 Without Opening It, Cap the screw hole: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. How to Clean Dust Out of a Playstation 5 Without Opening It, Close the cubby: 5 단계, 이미지 3개 중 1개 How to Clean Dust Out of a Playstation 5 Without Opening It, Close the cubby: 5 단계, 이미지 3개 중 2개 How to Clean Dust Out of a Playstation 5 Without Opening It, Close the cubby: 5 단계, 이미지 3개 중 3개
    • Twist the stand counterclockwise to close the cubby.
  6. How to Clean Dust Out of a Playstation 5 Without Opening It, Remove the horizontal stand: 6 단계, 이미지 2개 중 1개 How to Clean Dust Out of a Playstation 5 Without Opening It, Remove the horizontal stand: 6 단계, 이미지 2개 중 2개
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. How to Clean Dust Out of a Playstation 5 Without Opening It, Remove the left faceplate: 7 단계, 이미지 3개 중 1개 How to Clean Dust Out of a Playstation 5 Without Opening It, Remove the left faceplate: 7 단계, 이미지 3개 중 2개 How to Clean Dust Out of a Playstation 5 Without Opening It, Remove the left faceplate: 7 단계, 이미지 3개 중 3개
    • Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
  8. How to Clean Dust Out of a Playstation 5 Without Opening It: 8 단계, 이미지 2개 중 1개 How to Clean Dust Out of a Playstation 5 Without Opening It: 8 단계, 이미지 2개 중 2개
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the left faceplate.
  9. How to Clean Dust Out of a Playstation 5 Without Opening It, Vacuum out the dust: 9 단계, 이미지 3개 중 1개 How to Clean Dust Out of a Playstation 5 Without Opening It, Vacuum out the dust: 9 단계, 이미지 3개 중 2개 How to Clean Dust Out of a Playstation 5 Without Opening It, Vacuum out the dust: 9 단계, 이미지 3개 중 3개
    • Use a vacuum to clean out the two dust catchers.
    • A narrow vacuum attachment would be best.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
다른 50명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Robert Boyd
회원 가입일: 02/01/21
31,545 평판
안내서 94개를 작성함
2가이드 댓글
muchas gracias!!! muy facil acabo de hacerle una limpieza a mi consola
J4s3ph - 답글
댓글 쓰기
조회 통계:
지난 24시간: 74
지난 7일: 644
지난 30일: 2,959
전체 시간: 195,268
