주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Clean Mesh Shoes
필요한 것
  1. How to Clean Mesh Shoes, Prepare for cleaning: 1 단계, 이미지 3개 중 1개 How to Clean Mesh Shoes, Prepare for cleaning: 1 단계, 이미지 3개 중 2개 How to Clean Mesh Shoes, Prepare for cleaning: 1 단계, 이미지 3개 중 3개
    • Identify the type of dirt that the shoe is covered with.
    • Note: different types of dirt may require different cleaning approaches, in this example the shoe had soil and dust.
    • Gather all the tools needed for the repair.
    댓글 쓰기
  2. How to Clean Mesh Shoes, Brush off any dirt: 2 단계, 이미지 1개 중 1개
    • Using a dry soft brush to gently remove dirt and debris from the surface.
    댓글 쓰기
  3. How to Clean Mesh Shoes, Remove the laces and insert a shoe model or paper: 3 단계, 이미지 3개 중 1개 How to Clean Mesh Shoes, Remove the laces and insert a shoe model or paper: 3 단계, 이미지 3개 중 2개 How to Clean Mesh Shoes, Remove the laces and insert a shoe model or paper: 3 단계, 이미지 3개 중 3개
    • Take off the laces from your shoes to ensure a thorough clean.
    • Place a shoe model or crumpled paper inside each shoe to help maintain their shape during cleaning.
    댓글 쓰기
  4. How to Clean Mesh Shoes, Prepare the Cleaning Solution: 4 단계, 이미지 3개 중 1개 How to Clean Mesh Shoes, Prepare the Cleaning Solution: 4 단계, 이미지 3개 중 2개 How to Clean Mesh Shoes, Prepare the Cleaning Solution: 4 단계, 이미지 3개 중 3개
    • In a separate bowl, mix a small spoonful of baking soda with an equal amount of laundry detergent and twice the amount of water. Stir the mixture to create a paste.
    • Tip: adjust the quantity based on how dirty your shoes are.
    댓글 쓰기
  5. How to Clean Mesh Shoes, Clean with the Brush: 5 단계, 이미지 2개 중 1개 How to Clean Mesh Shoes, Clean with the Brush: 5 단계, 이미지 2개 중 2개
    • Dip the brush into the mixture and gently scrub the mesh surfaces of the shoes.
    댓글 쓰기
  6. How to Clean Mesh Shoes, Dry and Replace Laces: 6 단계, 이미지 2개 중 1개 How to Clean Mesh Shoes, Dry and Replace Laces: 6 단계, 이미지 2개 중 2개
    • Use a clean, dry cloth to wipe away any excess moisture and residue from the shoes.
    • Allow them to air dry completely and relace the sneaker.
    댓글 쓰기
  7. How to Clean Mesh Shoes, Finished and Ready!: 7 단계, 이미지 2개 중 1개 How to Clean Mesh Shoes, Finished and Ready!: 7 단계, 이미지 2개 중 2개
    • 🛠️🏆👏 Congratulations! The cleaning is complete, and you're ready to go!
    댓글 쓰기
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 68개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 172개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 40
전체 시간: 295
