주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Clean Nintendo Entertainment System Cartridges
필요한 것
  1. How to Clean Nintendo Entertainment System Cartridges, Take Apart the Cartridge: 1 단계, 이미지 1개 중 1개
    • Remove the three screws on the bottom of the cartridge. While most of the time the screws are security screws, sometimes there are Phillips/Flathead screws.
  2. How to Clean Nintendo Entertainment System Cartridges, Mix the Abrasive Paste: 2 단계, 이미지 2개 중 1개 How to Clean Nintendo Entertainment System Cartridges, Mix the Abrasive Paste: 2 단계, 이미지 2개 중 2개
    • Simply put about 2 tablespoons of baking soda on the cartridge contacts. Then put enough water on the baking soda until it is the consistency of a thick paste.
  3. How to Clean Nintendo Entertainment System Cartridges, Scrub the Contacts: 3 단계, 이미지 1개 중 1개
    • Take something like a toothbrush or the scraping part of a sponge and scrub the cartridge contacts.
    • After scrubbing for about 4-5 minutes, rinse the cartridge board off in the sink. Let it dry for about 4 hours after pouring alcohol under the chips.
결론
And with that your cartridge should be working properly!
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
[deleted]
회원 가입일: 06/12/22
569 평판
안내서 2개를 작성함
4가이드 댓글
Is this a joke?
Mizuho Chan - 답글 공유
Why would it be a joke? Because it's a simple procedure that everybody should know? Or do you have a better way?
Randall Mattoon - 공유
In my opinion, a less abrasive metal polish would probably be better to start with.
Jeff Griffith - 답글 공유
Whatever happened to the tried and true method of blowing on the cartridge? It worked as a kid (back when we didn’t know that our breath had water vapor and we were actually destroying our cartridges)!
mwbarnhart - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 29
지난 30일: 123
전체 시간: 5,418
