주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Clean Split Air Conditioner
필요한 것
  1. How to Clean Split Air Conditioner, How to Clean Split Air Conditioner: 1 단계, 이미지 1개 중 1개
    • The very first thing one has to do while leaning an air conditioner is to turn the unit off and then to unplug it.
  2. How to Clean Split Air Conditioner, Blow Air without Targeting the Air Reflectors: 2 단계, 이미지 1개 중 1개
    • Blow air to the air conditioner with air blower but make sure that the air pressure does not get to the air reflectors of the unit.
  3. How to Clean Split Air Conditioner, Use Cool Water: 3 단계, 이미지 1개 중 1개
    • Hot water is hazardous for the closely bound metallic plates as they may get expanded due to it. It is advised to use cool water while washing an air conditioner.
  4. How to Clean Split Air Conditioner, Place the Unit into a Drainable Place: 4 단계, 이미지 1개 중 1개
    • Garages, porches and courtyards are good places to clean or wash split air conditioners as they mostly have arrangements for water drainage.
  5. How to Clean Split Air Conditioner, Cover the Wires with Water Proof Material: 5 단계, 이미지 1개 중 1개
    • It is always better to cover the electric wires of air conditioner with water proofing material. If not done so, then there is a chance for the wires to get wet and this can lead to damage or short circuiting.
결승점
다른 9명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
markirwin
회원 가입일: 08/20/16
353 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 108
전체 시간: 9,197
