주요 콘텐츠로 건너뛰기
How to Clean The Exit Needle of the Keurig B60
필요한 것
  1. How to Clean The Exit Needle of the Keurig B60, How to Clean The Exit Needle of the Keurig B60: 1 단계, 이미지 1/1
    • Lift Handle to open Lid
  2. How to Clean The Exit Needle of the Keurig B60: 2 단계, 이미지 1/3 How to Clean The Exit Needle of the Keurig B60: 2 단계, 이미지 2/3 How to Clean The Exit Needle of the Keurig B60: 2 단계, 이미지 3/3
    • Remove K-Cup Pack Holder Assembly by pinching the left and right sides to release clamp. Wiggle slightly to remove
  3. How to Clean The Exit Needle of the Keurig B60: 3 단계, 이미지 1/3 How to Clean The Exit Needle of the Keurig B60: 3 단계, 이미지 2/3 How to Clean The Exit Needle of the Keurig B60: 3 단계, 이미지 3/3
    • Pull and snap apart the funnel from the K-Cup Pack Holder (If this is the first time separating the Pack Holder Assembly, more force may be required)
  4. How to Clean The Exit Needle of the Keurig B60: 4 단계, 이미지 1/2 How to Clean The Exit Needle of the Keurig B60: 4 단계, 이미지 2/2
    • Insert a paperclip or other small, sharp object into the bottom of the K-Cup Pack Holder needle compartment to clear out any debris. If debris is too dry and compact, perform this step under running water to loosen the debris
    • Flip K-Cup Pack Holder and repeat
  5. How to Clean The Exit Needle of the Keurig B60: 5 단계, 이미지 1/2 How to Clean The Exit Needle of the Keurig B60: 5 단계, 이미지 2/2
    • With the Lid still open, locate the Puncture Needle. Insert a paperclip or other small sharp object into the Puncture Needle Holes to remove any debris trapped inside
결론
Once reassembled, run the brewer once or twice with just water to cleanse the system.
다른 10명이 해당 안내서를 완성하였습니다.
Jake Wynn
회원 가입일: 04/11/16
830 평판
안내서 5개 작성하였습니다
Cal Poly, Team 1-7, Maness Spring 2016 Cal Poly, Team 1-7, Maness Spring 2016 회원
CPSU-MANESS-S16S1G7
5 회원들
안내서 5개 작성하였습니다
댓글 2개
I used the needle but it fell into the area.  How do I get the needle out?
pspicuzza - 답글
The bottom needle is loose on small piece of plastic is this normal or broke?
confused40 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 18
30일 전: 72
전체 시간: 26,658
