주요 콘텐츠로 건너뛰기
How to Clean Wooting Keyboard Lekker Linear45 Switches
필요한 것
  1. How to Clean Wooting Keyboard Lekker Linear45 Switches, How to Clean Wooting Keyboard Lekker Linear45 Switches: 1 단계, 이미지 3개 중 1개 How to Clean Wooting Keyboard Lekker Linear45 Switches, How to Clean Wooting Keyboard Lekker Linear45 Switches: 1 단계, 이미지 3개 중 2개 How to Clean Wooting Keyboard Lekker Linear45 Switches, How to Clean Wooting Keyboard Lekker Linear45 Switches: 1 단계, 이미지 3개 중 3개
    • Align the keycap puller so the prongs wrap underneath the sides of the keycap, then pull up to remove the keycap.
  2. How to Clean Wooting Keyboard Lekker Linear45 Switches: 2 단계, 이미지 3개 중 1개 How to Clean Wooting Keyboard Lekker Linear45 Switches: 2 단계, 이미지 3개 중 2개 How to Clean Wooting Keyboard Lekker Linear45 Switches: 2 단계, 이미지 3개 중 3개
    • Align the prongs of the switch puller so it clips underneath the grooves of the north and south side of the switch, then pull up.
    • Ensure a strong grip of the switch so the puller doesn’t slip out while pulling.
    • If you require an entire switch replacement, skip to Step 9 to re-insert the new switch.
  3. How to Clean Wooting Keyboard Lekker Linear45 Switches: 3 단계, 이미지 3개 중 1개 How to Clean Wooting Keyboard Lekker Linear45 Switches: 3 단계, 이미지 3개 중 2개 How to Clean Wooting Keyboard Lekker Linear45 Switches: 3 단계, 이미지 3개 중 3개
    • Identify the four prongs on the switch opener.
    • Align the switch onto the switch opener so that it sits flush on the prongs, then push down on the switch to disassemble the switch.
    • If you only want to replace the spring, move to Step 6 after disassembling the switch.
  4. How to Clean Wooting Keyboard Lekker Linear45 Switches: 4 단계, 이미지 2개 중 1개 How to Clean Wooting Keyboard Lekker Linear45 Switches: 4 단계, 이미지 2개 중 2개
    • Identify the various switch components and the order of construction (from left to right or bottom to top): bottom housing, spring, stem, top housing. Separate them from the switch.
  5. How to Clean Wooting Keyboard Lekker Linear45 Switches: 5 단계, 이미지 2개 중 1개 How to Clean Wooting Keyboard Lekker Linear45 Switches: 5 단계, 이미지 2개 중 2개
    • Identify the individual parts and see if any parts are dirty to the degree that it could interfere with the magnet sensor.
    • Clean out the dust or debris thoroughly with a cotton swab.
    • Optional: In the case where extensive cleaning is required, use isopropyl alcohol.
  6. How to Clean Wooting Keyboard Lekker Linear45 Switches: 6 단계, 이미지 2개 중 1개 How to Clean Wooting Keyboard Lekker Linear45 Switches: 6 단계, 이미지 2개 중 2개
    • Hold the bottom housing such that the inner cylinder faces up.
    • Slip the spring onto the cylinder.
  7. How to Clean Wooting Keyboard Lekker Linear45 Switches: 7 단계, 이미지 1개 중 1개
    • Place the stem so the magnet faces the bottom housing, and the stem mount faces up.
    • Orient the stem so the side notches at the top face the sides of the switch.
  8. How to Clean Wooting Keyboard Lekker Linear45 Switches: 8 단계, 이미지 1개 중 1개
    • Place the top housing on top of the stem and align it so the LED window faces north.
    • Clip the switch parts together into place.
    • If aligned correctly, the switch components will snap together without coming apart.
  9. How to Clean Wooting Keyboard Lekker Linear45 Switches: 9 단계, 이미지 3개 중 1개 How to Clean Wooting Keyboard Lekker Linear45 Switches: 9 단계, 이미지 3개 중 2개 How to Clean Wooting Keyboard Lekker Linear45 Switches: 9 단계, 이미지 3개 중 3개
    • Align the switch into the board such that the LED window is facing north.
    • Push down so the switch clips into place and isn’t loose.
  10. How to Clean Wooting Keyboard Lekker Linear45 Switches: 10 단계, 이미지 3개 중 1개 How to Clean Wooting Keyboard Lekker Linear45 Switches: 10 단계, 이미지 3개 중 2개 How to Clean Wooting Keyboard Lekker Linear45 Switches: 10 단계, 이미지 3개 중 3개
    • Align the keycap so it faces the correct orientation.
    • The bottom of the keycap should have an indent in the shape of the keycap/stem mount which fits onto the mount sticking out from the switch.
    • Press down the keycap onto the switch.
결승점
작성자
3다른 기여자 명과 함께
Annie Ding
회원 가입일: 02/21/25
181 평판
안내서 1개를 작성함
UC Davis, Team 1-1, Andersen Winter 2025 UC Davis, Team 1-1, Andersen Winter 2025 회원
UCD-ANDERSEN-W25S1G1
4 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 20
전체 시간: 173
