주요 콘텐츠로 건너뛰기
How to Clean a Canon PowerShot SD780 IS Shutter Button
필요한 것
  1. How to Clean a Canon PowerShot SD780 IS Shutter Button, How to Clean a Canon PowerShot SD780 IS Shutter Button: 1 단계, 이미지 1개 중 1개
    • Before starting, make sure to turn off the camera and remove the battery.
  2. How to Clean a Canon PowerShot SD780 IS Shutter Button: 2 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove the five outermost screws from the camera.
  3. How to Clean a Canon PowerShot SD780 IS Shutter Button: 3 단계, 이미지 1개 중 1개
    • Remove the front panel of the camera case to expose the top left ribbon cable. Pull the ribbon cable gently to disconnect it from the camera.
  4. How to Clean a Canon PowerShot SD780 IS Shutter Button: 4 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver remove the single screw on the far left-hand side towards the bottom of the camera.
  5. How to Clean a Canon PowerShot SD780 IS Shutter Button: 5 단계, 이미지 1개 중 1개
    • Carefully pull the case apart to separate the 2 pieces.
    • The case will detach from the camera in two pieces.
  6. How to Clean a Canon PowerShot SD780 IS Shutter Button: 6 단계, 이미지 1개 중 1개
    • Remove the two screws on the metal plate of the camera case. This will give you access to the spring inside the metal plate for further cleaning.
    • Clean the inside of the camera with a cloth to remove dust and excess grime. This should unstick the shutter button and allow for full function.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Arlene Ale
회원 가입일: 03/13/14
455 평판
안내서 4개를 작성함
New Mexico State, Team 1-5, Easley Spring 2014 New Mexico State, Team 1-5, Easley Spring 2014 회원
NMSU-EASLEY-S14S1G5
2 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 27
전체 시간: 1,084
