주요 콘텐츠로 건너뛰기
How to Clean a Clouded Glass Oven Door
필요한 것
  1. How to Clean a Clouded Glass Oven Door, How to Clean a Clouded Glass Oven Door: 1 단계, 이미지 1/3 How to Clean a Clouded Glass Oven Door, How to Clean a Clouded Glass Oven Door: 1 단계, 이미지 2/3 How to Clean a Clouded Glass Oven Door, How to Clean a Clouded Glass Oven Door: 1 단계, 이미지 3/3
    • Open the oven door until it lays flat.
  2. How to Clean a Clouded Glass Oven Door: 2 단계, 이미지 1/3 How to Clean a Clouded Glass Oven Door: 2 단계, 이미지 2/3 How to Clean a Clouded Glass Oven Door: 2 단계, 이미지 3/3
    • Add a tablespoon of baking soda to a medium size bowl.
    • Pour 1 cup of vinegar into the bowl.
    • Mix the solution together.
  3. How to Clean a Clouded Glass Oven Door: 3 단계, 이미지 1/3 How to Clean a Clouded Glass Oven Door: 3 단계, 이미지 2/3 How to Clean a Clouded Glass Oven Door: 3 단계, 이미지 3/3
    • Pour the mix on the open oven glass door, making sure to cover the entire area.
    • Leave it for about 45 minutes
    • You might notice the mixture bubbling and rising. Wait until it simmers down but continues to bubble.
  4. How to Clean a Clouded Glass Oven Door: 4 단계, 이미지 1/3 How to Clean a Clouded Glass Oven Door: 4 단계, 이미지 2/3 How to Clean a Clouded Glass Oven Door: 4 단계, 이미지 3/3
    • 30 minutes - 1 hour later, use a stainless steel sponge to scrub the glass door. The mix aids in loosening deep stains.
    • Keep scrubbing until the surface feels clean and the stains are gone.
    • If your arm is getting tried from the intense scrubbing, take a break!
  5. How to Clean a Clouded Glass Oven Door: 5 단계, 이미지 1/3 How to Clean a Clouded Glass Oven Door: 5 단계, 이미지 2/3 How to Clean a Clouded Glass Oven Door: 5 단계, 이미지 3/3
    • Once the stains are gone, use a towel to clean off the residue and remaining mixture.
    • Rinse the residue off the towel and repeat until the door is entirely clean of dirt and mixture residue.
  6. How to Clean a Clouded Glass Oven Door: 6 단계, 이미지 1/3 How to Clean a Clouded Glass Oven Door: 6 단계, 이미지 2/3 How to Clean a Clouded Glass Oven Door: 6 단계, 이미지 3/3
    • Add soap and water to a sponge and gently clean the oven door.
    • Use a damp towel to wipe off the soap, then use a paper towel to thoroughly dry the oven glass door, ensuring there is no leftover water.
결론
Enjoy you clean glass oven door!
다른 한 분이 해당 안내서를 완성하였습니다.
Zion-Faith Akakpo
회원 가입일: 01/08/24
133 평판
안내서 1개 작성함
York University, Team 2-1, O'Regan Winter 2024 York University, Team 2-1, O'Regan Winter 2024 회원
YORK-O'REGAN-W24S2G1
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 40
전체 시간: 113
