주요 콘텐츠로 건너뛰기
How to Clean a Dirt Devil Vacuum Cleaner Roller Brush
필요한 것
  1. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush, How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 1 단계, 이미지 1/1
    • Lay the vacuum cleaner on the floor so that the bottom of the vacuum is facing upwards.
  2. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 2 단계, 이미지 1/1
    • Use a Phillips head screwdriver to remove eight screws.
  3. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 3 단계, 이미지 1/1
    • Disassemble the vacuum head and pop out your roller brush.
  4. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 4 단계, 이미지 1/1
    • Cut the ends with scissors.
    • Cover the floor with papers to prevent debris and hair from falling on the ground.
  5. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 5 단계, 이미지 1/1
    • Use a brush to clean the roller brush.
  6. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 6 단계, 이미지 1/2 How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 6 단계, 이미지 2/2
    • Put the rectangular part on both sides.
  7. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 7 단계, 이미지 1/2 How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 7 단계, 이미지 2/2
    • Check if the belt is attached.
    • Check if the motor part is well inserted with the belt attached to the roller brush.
    • Make sure the shape of the motor fits to prevent it from falling.
  8. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 8 단계, 이미지 1/1
    • Use your Phillips head screwdriver to screw in all eight of the screws.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Minji Choi
회원 가입일: 02/21/21
184 평판
안내서 1개 작성함
댓글 4개
Might be helpful if you showed where all 8 screws are seeing how I can only find 6 and cannot get it open!
Crystal - 답글
in the front there are to wheels, pop them out and you will see the other 2 screws
Mario Lore -
my power express lite only has 6 screws as well. I cannot get it open, I'm afraid it will break if I keep prying.
Gregory Penniston - 답글
Can I hand wash the brushes and rollers.
Lynne - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 52
30일 전: 235
전체 시간: 8,169
