주요 콘텐츠로 건너뛰기
How to Clean a Dyson Airwrap Styler Filter
  1. How to Clean a Dyson Airwrap Styler Filter, How to Clean a Dyson Airwrap Styler Filter: 1 단계, 이미지 2개 중 1개 How to Clean a Dyson Airwrap Styler Filter, How to Clean a Dyson Airwrap Styler Filter: 1 단계, 이미지 2개 중 2개
    • Unplug the Dyson Airwrap from the wall outlet.
    • Locate the filter cleaning brush.
  2. How to Clean a Dyson Airwrap Styler Filter: 2 단계, 이미지 3개 중 1개 How to Clean a Dyson Airwrap Styler Filter: 2 단계, 이미지 3개 중 2개 How to Clean a Dyson Airwrap Styler Filter: 2 단계, 이미지 3개 중 3개
    • Find the open side of the filter cleaning brush.
    • Thread it through the Dyson cord.
  3. How to Clean a Dyson Airwrap Styler Filter: 3 단계, 이미지 2개 중 1개 How to Clean a Dyson Airwrap Styler Filter: 3 단계, 이미지 2개 중 2개
    • Pull the brush over the hair styler.
    • Rotate the bristles around the air filter.
    • While rotating the bristles, blow away any excess dust.
    • Do not use any chemicals or liquids to wipe away the dust.
  4. How to Clean a Dyson Airwrap Styler Filter: 4 단계, 이미지 2개 중 1개 How to Clean a Dyson Airwrap Styler Filter: 4 단계, 이미지 2개 중 2개
    • Gently pull the bottom air filter piece off of the hair styler, but do not pull it off the cord completely.
  5. How to Clean a Dyson Airwrap Styler Filter: 5 단계, 이미지 3개 중 1개 How to Clean a Dyson Airwrap Styler Filter: 5 단계, 이미지 3개 중 2개 How to Clean a Dyson Airwrap Styler Filter: 5 단계, 이미지 3개 중 3개
    • Gently rotate the filter cleaner brush around the exposed air filter.
    • Blow away any dust that may come off.
  6. How to Clean a Dyson Airwrap Styler Filter: 6 단계, 이미지 1개 중 1개
    • Place the air filter piece back on.
    • You will know when it’s on correctly because it will click into place.
    • Do not force the piece back on.
결승점
첨부 문서
작성자
2다른 기여자 명과 함께
Clare Houliston
회원 가입일: 01/12/22
133 평판
안내서 1개를 작성함
1가이드 댓글
Bei meinem Airwrap zieht er nicht genug Luft, erst wenn ich den Filter entferne schafft er es die Haare am Lockenaufsatzt zu wickeln. Ich habe mittel langes Haar und nicht wirklich dicke Haare, die ersten 2 Monate ging eigentlich noch alles aber jetzt muss ich den Filter abnehmen und das Metallstück am Ende offen lasen damit der Airwrap überhaupt irgendwas schafft. Wie kann ich meinen Airwrap wieder reparieren?
Double B - 답글
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 103
지난 30일: 578
전체 시간: 53,270
