주요 콘텐츠로 건너뛰기
How to Clean a Filter on a MAYTAG Laundry Machine
필요한 것
  1. How to Clean a Filter on a MAYTAG Laundry Machine, How to Clean a Filter on a MAYTAG Laundry Machine: 1 단계, 이미지 1/3 How to Clean a Filter on a MAYTAG Laundry Machine, How to Clean a Filter on a MAYTAG Laundry Machine: 1 단계, 이미지 2/3 How to Clean a Filter on a MAYTAG Laundry Machine, How to Clean a Filter on a MAYTAG Laundry Machine: 1 단계, 이미지 3/3
    • Remove the screws (3) underneath the washing machine using the socket wrench, the extension rod, and the converter.
  2. How to Clean a Filter on a MAYTAG Laundry Machine: 2 단계, 이미지 1/3 How to Clean a Filter on a MAYTAG Laundry Machine: 2 단계, 이미지 2/3 How to Clean a Filter on a MAYTAG Laundry Machine: 2 단계, 이미지 3/3
    • Put a tray/rags underneath the washing machine in case water leaks out.
    • Remove the bottom lid of the washing machine.
  3. How to Clean a Filter on a MAYTAG Laundry Machine: 3 단계, 이미지 1/1
    • Turn the filter counterclockwise until you can pull out the filter.
  4. How to Clean a Filter on a MAYTAG Laundry Machine: 4 단계, 이미지 1/3 How to Clean a Filter on a MAYTAG Laundry Machine: 4 단계, 이미지 2/3 How to Clean a Filter on a MAYTAG Laundry Machine: 4 단계, 이미지 3/3
    • Scrub/wash the filter of debris.
  5. How to Clean a Filter on a MAYTAG Laundry Machine: 5 단계, 이미지 1/1
    • Screw the filter clockwise back into place.
결승점
Kaelyn Taing
회원 가입일: 10/26/22
121 평판
안내서 1개 작성함
CSU Los Angeles, Team 50-50, Briggs Fall 2022 CSU Los Angeles, Team 50-50, Briggs Fall 2022 회원
CSULA-BRIGGS-F22S50G50
1 회원
안내서 2개 작성하였습니다
댓글 한 개
A tricky part of this maintenance task is removing and replacing the front cover behind which the filter resides. This guide is inadequate for that part of the job.
Carlo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 14
7일 전: 94
30일 전: 443
전체 시간: 7,363
