주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Clean a Flat Iron
필요한 것
  1. How to Clean a Flat Iron, How to Clean a Flat Iron: 1 단계, 이미지 1개 중 1개
    • Lay out your cloth over your working surface.
    • Set flat iron aside.
    • The Flat Iron should never be plugged in while cleaning.
  2. How to Clean a Flat Iron: 2 단계, 이미지 2개 중 1개 How to Clean a Flat Iron: 2 단계, 이미지 2개 중 2개
    • Scoop the baking soda (1-3 Tbsp) into your small bowl or cup.
    • You may need more or less baking soda depending on the size of the your iron's plates.
  3. How to Clean a Flat Iron: 3 단계, 이미지 2개 중 1개 How to Clean a Flat Iron: 3 단계, 이미지 2개 중 2개
    • Add the hydrogen peroxide to the bowl containing the baking soda and stir until a thick paste is formed.
    • Approximately 10 drops of the hydrogen peroxide is needed per tablespoon of the baking soda.
    • The consistency of the paste should be similar to a thick and grainy toothpaste.
  4. How to Clean a Flat Iron: 5 단계, 이미지 2개 중 1개 How to Clean a Flat Iron: 5 단계, 이미지 2개 중 2개
    • Smear a thick layer of the paste onto the plates of the iron.
    • Let sit for 5 minutes.
  5. How to Clean a Flat Iron: 6 단계, 이미지 2개 중 1개 How to Clean a Flat Iron: 6 단계, 이미지 2개 중 2개
    • Let the paste sit on the plates for 5 minutes before proceeding.
    • Wipe off the excess but not ALL of the paste with the sponge into the small bowl.
  6. How to Clean a Flat Iron: 7 단계, 이미지 1개 중 1개
    • Use your cloth or sponge to scrub the plates of the flat iron until all the buildup is removed.
    • This process may take 2-5 minutes depending on the amount of buildup on your iron.
  7. How to Clean a Flat Iron: 8 단계, 이미지 1개 중 1개
    • Once all of the buildup is removed, wipe off all the remaining paste into your bowl.
  8. How to Clean a Flat Iron: 9 단계, 이미지 1개 중 1개
    • Dispose the baking soda paste into a sink or trash can.
    • Your Flat Iron is now clean!
결론
Congratulations your flat iron is buildup free!
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jacquelin
회원 가입일: 02/23/15
283 평판
안내서 1개를 작성함
Cal Poly, Team 12-2, Green Winter 2015 Cal Poly, Team 12-2, Green Winter 2015 회원
CPSU-GREEN-W15S12G2
6 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 49
전체 시간: 6,523
