주요 콘텐츠로 건너뛰기
How to Clean a Kenmore 70101 Wall/Window AC Filter
필요한 것
  1. How to Clean a Kenmore 70101 Wall/Window AC Filter, How to Clean a Kenmore 70101 Wall/Window AC Filter: 1 단계, 이미지 1/2 How to Clean a Kenmore 70101 Wall/Window AC Filter, How to Clean a Kenmore 70101 Wall/Window AC Filter: 1 단계, 이미지 2/2
    • Open the front grille of the AC.
  2. How to Clean a Kenmore 70101 Wall/Window AC Filter: 2 단계, 이미지 1/2 How to Clean a Kenmore 70101 Wall/Window AC Filter: 2 단계, 이미지 2/2
    • Unsnap or unclip the filter from its mount and lift it from the slot.
  3. How to Clean a Kenmore 70101 Wall/Window AC Filter: 3 단계, 이미지 1/2 How to Clean a Kenmore 70101 Wall/Window AC Filter: 3 단계, 이미지 2/2
    • Thoroughly wash the filter's panels with water and a mild soap or dishwashing liquid.
    • Completely rinse the soap from the filter's surface.
  4. How to Clean a Kenmore 70101 Wall/Window AC Filter: 4 단계, 이미지 1/2 How to Clean a Kenmore 70101 Wall/Window AC Filter: 4 단계, 이미지 2/2
    • Dab the filter with a soft towel to remove most of the water, then allow time for the filter to completely air dry.
    • Return the filter to its original place behind the AC's front grille.
  5. How to Clean a Kenmore 70101 Wall/Window AC Filter: 5 단계, 이미지 1/2 How to Clean a Kenmore 70101 Wall/Window AC Filter: 5 단계, 이미지 2/2
    • Firmly close the front grille.
결론
Cleaning your AC's filter is fast, easy, and more cost-efficient than buying an entirely new one. Enjoy the cool air!
다른 한 분이 해당 안내서를 완성하였습니다.
Vashante Johnson
회원 가입일: 10/27/22
145 평판
안내서 1개 작성함
University of Memphis, Team 51-10, Kim Fall 2022 University of Memphis, Team 51-10, Kim Fall 2022 회원
UM-KIM-F22S51G10
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 30
7일 전: 117
30일 전: 370
전체 시간: 2,774
