주요 콘텐츠로 건너뛰기
How to Clean a Mainstays Coffee Maker Water Tube
필요한 것
  1. How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: 1 단계, 이미지 3개 중 1개 How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: 1 단계, 이미지 3개 중 2개 How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: 1 단계, 이미지 3개 중 3개
    • Open the top of the coffee maker.
  2. How to Clean a Mainstays Coffee Maker Water Tube: 2 단계, 이미지 2개 중 1개 How to Clean a Mainstays Coffee Maker Water Tube: 2 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the four 6 mm screws surrounding the puncturing needle.
  3. How to Clean a Mainstays Coffee Maker Water Tube: 3 단계, 이미지 3개 중 1개 How to Clean a Mainstays Coffee Maker Water Tube: 3 단계, 이미지 3개 중 2개 How to Clean a Mainstays Coffee Maker Water Tube: 3 단계, 이미지 3개 중 3개
    • Press down on the brew chamber release button and remove the backing piece.
  4. How to Clean a Mainstays Coffee Maker Water Tube: 4 단계, 이미지 3개 중 1개 How to Clean a Mainstays Coffee Maker Water Tube: 4 단계, 이미지 3개 중 2개 How to Clean a Mainstays Coffee Maker Water Tube: 4 단계, 이미지 3개 중 3개
    • Disconnect the water tube from where it is connected to the needle.
  5. How to Clean a Mainstays Coffee Maker Water Tube: 5 단계, 이미지 3개 중 1개 How to Clean a Mainstays Coffee Maker Water Tube: 5 단계, 이미지 3개 중 2개 How to Clean a Mainstays Coffee Maker Water Tube: 5 단계, 이미지 3개 중 3개
    • Flip the coffee maker upside down.
  6. How to Clean a Mainstays Coffee Maker Water Tube: 6 단계, 이미지 2개 중 1개 How to Clean a Mainstays Coffee Maker Water Tube: 6 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the four 7 mm screws on the base of the coffee maker.
  7. How to Clean a Mainstays Coffee Maker Water Tube: 7 단계, 이미지 3개 중 1개 How to Clean a Mainstays Coffee Maker Water Tube: 7 단계, 이미지 3개 중 2개 How to Clean a Mainstays Coffee Maker Water Tube: 7 단계, 이미지 3개 중 3개
    • Remove the base.
  8. How to Clean a Mainstays Coffee Maker Water Tube: 8 단계, 이미지 2개 중 1개 How to Clean a Mainstays Coffee Maker Water Tube: 8 단계, 이미지 2개 중 2개
    • Use an 8" Phillips screwdriver to remove the five internal 14 mm screws from within the coffee maker.
    • Use an 8" Phillips screwdriver to remove the six internal 7 mm screws from within the coffee maker.
    • The second image shows the approximate placement of the screws; you may have to reach inside and move wires to locate and access all eleven screws.
  9. How to Clean a Mainstays Coffee Maker Water Tube: 9 단계, 이미지 3개 중 1개 How to Clean a Mainstays Coffee Maker Water Tube: 9 단계, 이미지 3개 중 2개 How to Clean a Mainstays Coffee Maker Water Tube: 9 단계, 이미지 3개 중 3개
    • Flip the coffee maker right-side up.
  10. How to Clean a Mainstays Coffee Maker Water Tube: 10 단계, 이미지 3개 중 1개 How to Clean a Mainstays Coffee Maker Water Tube: 10 단계, 이미지 3개 중 2개 How to Clean a Mainstays Coffee Maker Water Tube: 10 단계, 이미지 3개 중 3개
    • Pull the disconnected end of the water tube out of the top of the coffee maker.
  11. How to Clean a Mainstays Coffee Maker Water Tube: 11 단계, 이미지 1개 중 1개
    • Move the top of the coffee maker out of the way so that you can reach into the base.
    • You may wish to put something under the top to support it.
  12. How to Clean a Mainstays Coffee Maker Water Tube: 12 단계, 이미지 3개 중 1개 How to Clean a Mainstays Coffee Maker Water Tube: 12 단계, 이미지 3개 중 2개 How to Clean a Mainstays Coffee Maker Water Tube: 12 단계, 이미지 3개 중 3개
    • Identify where the water tube is connected at the other end.
    • Use pliers or your hand to disconnect it.
    • If you choose to use pliers, take caution not to puncture the tube.
  13. How to Clean a Mainstays Coffee Maker Water Tube: 13 단계, 이미지 3개 중 1개 How to Clean a Mainstays Coffee Maker Water Tube: 13 단계, 이미지 3개 중 2개 How to Clean a Mainstays Coffee Maker Water Tube: 13 단계, 이미지 3개 중 3개
    • Locate any blockages in the water tube and use your chosen tool (chenille stick, wooden dowel, toothpick, etc.) to push them out.
    • If the tube looks cloudy, use a chenille stick to break up the buildup.
  14. How to Clean a Mainstays Coffee Maker Water Tube: 14 단계, 이미지 1개 중 1개
    • Rinse any remaining debris out of the tube.
    • Depending on what tool you chose to use in the previous step, particles from said tool may need to be rinsed out as well.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Lorelei Kriss
회원 가입일: 01/30/24
269 평판
안내서 1개를 작성함
UC Davis, Team 4-9, Andersen Winter 2024 UC Davis, Team 4-9, Andersen Winter 2024 회원
UCD-ANDERSEN-W24S4G9
2 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 73
전체 시간: 1,328
