주요 콘텐츠로 건너뛰기
How to Clean a Martin Yale 1611 Folding Machine
필요한 것
  1. How to Clean a Martin Yale 1611 Folding Machine, How to Clean a Martin Yale 1611 Folding Machine: 1 단계, 이미지 1/3 How to Clean a Martin Yale 1611 Folding Machine, How to Clean a Martin Yale 1611 Folding Machine: 1 단계, 이미지 2/3 How to Clean a Martin Yale 1611 Folding Machine, How to Clean a Martin Yale 1611 Folding Machine: 1 단계, 이미지 3/3
    • Use a Phillips #00 screwdriver to remove both screws on the ends of the top cover.
    • Once the screws are removed, lift the cover upwards to remove.
  2. How to Clean a Martin Yale 1611 Folding Machine: 2 단계, 이미지 1/1
    • To remove the first fold table, tilt it upwards and pull it away from the machine to slide it out.
  3. How to Clean a Martin Yale 1611 Folding Machine: 3 단계, 이미지 1/1
    • To remove the second fold table, tilt it upwards and pull it away from the machine to slide it out.
  4. How to Clean a Martin Yale 1611 Folding Machine: 4 단계, 이미지 1/1
    • Apply your dish soap to a small dampened sponge.
    • Make sure not to over soak the sponge or add too much soap.
  5. How to Clean a Martin Yale 1611 Folding Machine: 5 단계, 이미지 1/3 How to Clean a Martin Yale 1611 Folding Machine: 5 단계, 이미지 2/3 How to Clean a Martin Yale 1611 Folding Machine: 5 단계, 이미지 3/3
    • Carefully rub the sponge along each roller.
    • Turn each roller as you clean it to ensure it is completely cleaned.
    • Any dark (black) residue present on the sponge indicates an ink build up, so continue cleaning until all residue is gone.
결론
Before reassembling, make sure all of the rollers are dry (you may use a cotton cloth). To reassemble your device, follow steps 1-3 in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Ashley Jones
회원 가입일: 09/20/20
178 평판
안내서 1개 작성함
University of Memphis, Team S1-G9, Bishop Fall 2020 University of Memphis, Team S1-G9, Bishop Fall 2020 회원
UM-BISHOP-F20S1G9
1 회원
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 26
전체 시간: 842
