주요 콘텐츠로 건너뛰기
How to Clean a PVC P-Trap
필요한 것
  1. How to Clean a PVC P-Trap, How to Clean a PVC P-Trap: 1 단계, 이미지 1개 중 1개
    • Clear out the space if the trap is located in a hard-to-reach place.
    • Turn off the water valve for the sink.
  2. How to Clean a PVC P-Trap: 2 단계, 이미지 1개 중 1개
    • Place towels around the area.
    • Place a bucket or bowl under the P-trap.
  3. How to Clean a PVC P-Trap: 3 단계, 이미지 3개 중 1개 How to Clean a PVC P-Trap: 3 단계, 이미지 3개 중 2개 How to Clean a PVC P-Trap: 3 단계, 이미지 3개 중 3개
    • Loosen the coupling nuts from the pipe above and below the drain using a wrench.
  4. How to Clean a PVC P-Trap: 4 단계, 이미지 3개 중 1개 How to Clean a PVC P-Trap: 4 단계, 이미지 3개 중 2개 How to Clean a PVC P-Trap: 4 단계, 이미지 3개 중 3개
    • Loosen the nuts on the upper and lower pipe and disconnect the the P-trap.
    • Remove the U shape from the piping, and dump any water into bowl.
    • Pull the PVC pipe that is connected to the wall out horizontally.
    • Pull the PVC pipe closest to the drain in a downward motion.
  5. How to Clean a PVC P-Trap: 5 단계, 이미지 3개 중 1개 How to Clean a PVC P-Trap: 5 단계, 이미지 3개 중 2개 How to Clean a PVC P-Trap: 5 단계, 이미지 3개 중 3개
    • Empty any water into a bucket.
    • Clear out the interior of the PVC pipe using a bottle brush or wire, spinning and moving the brush through the pipe.
    • Remove any soap scum.
    • This may appear black and sludge-like.
  6. How to Clean a PVC P-Trap: 6 단계, 이미지 3개 중 1개 How to Clean a PVC P-Trap: 6 단계, 이미지 3개 중 2개 How to Clean a PVC P-Trap: 6 단계, 이미지 3개 중 3개
    • Using a different water source, run the hot water through the P-trap parts.
    • Check that the P-Trap parts are clear.
  7. How to Clean a PVC P-Trap: 7 단계, 이미지 3개 중 1개 How to Clean a PVC P-Trap: 7 단계, 이미지 3개 중 2개 How to Clean a PVC P-Trap: 7 단계, 이미지 3개 중 3개
    • Reassemble the trap, but leave the horizontal pipe disconnected.
    • Insert the short pipe into the the U shape and loosely tighten the nut.
  8. How to Clean a PVC P-Trap: 8 단계, 이미지 3개 중 1개 How to Clean a PVC P-Trap: 8 단계, 이미지 3개 중 2개 How to Clean a PVC P-Trap: 8 단계, 이미지 3개 중 3개
    • Insert the horizontal pipe back into the water output in the wall. Begin to tighten the nut closest to the wall.
  9. How to Clean a PVC P-Trap: 9 단계, 이미지 3개 중 1개 How to Clean a PVC P-Trap: 9 단계, 이미지 3개 중 2개 How to Clean a PVC P-Trap: 9 단계, 이미지 3개 중 3개
    • Insert the top of the P-trap back onto drain pipe.
    • Align the pipes so the pipes are touching.
    • Once aligned, secure all the nuts tightly.
  10. How to Clean a PVC P-Trap: 10 단계, 이미지 2개 중 1개 How to Clean a PVC P-Trap: 10 단계, 이미지 2개 중 2개
    • Turn the water valve back on to check the P-Trap for leaks.
    • Run hot water for 30 seconds or more, and use your hand to feel for any leaking.
    • If you do, identify which section is leaking and tighten the nut.
    • If it continues to leak, you may need to use threading tape, which is shown in the next step.
  11. How to Clean a PVC P-Trap: 11 단계, 이미지 3개 중 1개 How to Clean a PVC P-Trap: 11 단계, 이미지 3개 중 2개 How to Clean a PVC P-Trap: 11 단계, 이미지 3개 중 3개
    • Take the P -trap off after locating the leak.
    • Use the threading tape on the PVC pipe to help the nuts tighten. Simply wrap the threading tape around the threading on the pipe where the leak was found.
    • Put the PVC P-trap back on and tighten the nuts.
    • Turn the water back on as you check for leaks.
    • wrap the tape in a clockwise direction around the pipe threads.
  12. How to Clean a PVC P-Trap: 13 단계, 이미지 1개 중 1개
    • Put the P trap back into place.
    • Give the P-trap one more look to ensure all the nuts are tightened.
    • Double check alignment and you are finished.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ashley m. Wuthrich -Hoffman
회원 가입일: 11/17/21
229 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 19
전체 시간: 1,859
